Need more info
I've done the search on the p0748 code and know what it is. Does anyone know why I would get this code just by dropping the pan and changing the filter, andjusting the bands, and filling the tranny. Truck is still on the jack stands in the garage. All I did was start the truck and slowly go through the gears with the brake on. I cleared the code last night and started the truck this morning and it tripped again. I'm a little confused but maybe when I adjusted the front bands could I have knocked the sensor somehow? Could it be from not topping off the fluid yet?
Trans is a 46re.
Thanks for any advice.
Trans is a 46re.
Drain plug was just put in this service so eventhough I don't want to pull the pan the plug I installed will make it easier. I'm new to this transmission stuff so I'll ask...is it behind (above) the filter I installed? A picture would be great if you are able to direct me to a site that would show me.
Thanks for the responses.
Trending Topics
SYMPTOM
P0748-PRESSURE SOL CONTROL/TRANS RELAY CIRCUITS
WHEN MONITORED
Continuously with the key ON.
SET CONDITION
This code will set if the voltage detected on the Governor Pressure Solenoid Control circuit at the PCM is different than the expected voltage.
POSSIBLE CAUSES
P1765 DTC present
Intermittent governor pressure solenoid
Transmission relay output
Fused B+ circuit open
Governor pressure solenoid control circuit open
Governor pressure solenoid control circuit open internal
Transmission control relay output circuit open
Governor pressure solenoid control circuit short to ground
Governor pressure solenoid control circuit short to ground internal
Transmission relay output circuit short to ground
Governor pressure solenoid control circuit short to voltage
Governor pressure solenoid control circuit short to solenoid circuits internal
Governor pressure solenoid control circuit short to other circuits
Governor pressure solenoid control circuit short to other circuits internal
Transmission control relay - poor contacts
PCM - governor pressure solenoid control circuit
WHEN MONITORED
SET CONDITION
POSSIBLE CAUSES
P1765 DTC present
