A slug in rainy weather
Old Mar 10, 2009 | 01:43 PM
  #21
TMS Bill's Avatar
TMS Bill
Everything with a distributor still needs a coil ... it's what steps the 12 volts up to 30k or 50k or whatever the secondary system wants. The "coil packs" are little coils directly in line with the plugs without a distributor.
Yes, you have one coil.
Old Mar 10, 2009 | 01:46 PM
  #22
dblj16380's Avatar
dblj16380
Thanks. Damn, I feel stupid. I can rebuild a transmission but didn't know that I had an ignition coil!
Old Mar 10, 2009 | 08:55 PM
  #23
wjxavier's Avatar
wjxavier
yep, it was definitely the coil. at least i have pretty much all new ignition stuff now lol
Old Mar 11, 2009 | 06:53 AM
  #24
dblj16380's Avatar
dblj16380
I still don't understand how a bad coil could cause my truck to run rough in low gears in the rain but great when I pop it into Neutral?
Old Mar 11, 2009 | 07:03 AM
  #25
wjxavier's Avatar
wjxavier
mine did the exact same thing. it eventually got to the point where it wasn't raining for a while, so i just forgot about it, then we got a huge snow storm, lots of wetness, and it finally just gave the boot and ran crappy ALL the time. idk, maybe your case is different. it's only 30 bucks for a OE replacement coil. just get one, replace it, test it out, if it doesnt work, then take it back lol
Old Mar 22, 2009 | 08:15 AM
  #26
ryker's Avatar
ryker
My manual trans truck has been having starting issues in the rain or moisture. At first I thought it was bad gas or parking it on the grass. Off to the parts store to buy a coil.
Old Mar 22, 2009 | 08:51 AM
  #27
aim4squirrels's Avatar
aim4squirrels
Or you could diagnose correctly and check the distributor cap for cracks, test the wires for resistance, check plug straps and gaps, put dielectric grease on the connection points, and the coil for spark and then you'll know what's wrong.
