Anyone Have This Problem??
Old Mar 16, 2009 | 02:08 PM
dodgeram32's Avatar
dodgeram32
Default Anyone Have This Problem??
I have a 99 Dodge Ram reg cab short box 4x4 sport 5.9 360, i was in some mud the other day and noticed a click click click almost snappy like sound, so I put the truck back in 2 wheel drive and left, i checked the truck out and I didnt notice anything out of the ordinary, so i took it to the shop was told i need new U joints so i replaced the 2 driveshaft U joints and tie rod and tie rod end.
The truck still clicks best way to describe it is something snapping or binding? Now the truck does this in 2 wheel drive when turning left or right, and they sound greatly increases when in 4wd HI with even a slight turn (no sound when truck is at idle)
i also have a constant squeaking when driving, it doesnt sound like a belt its about from the middle to back of the truck.
Any Ideas??
Old Mar 16, 2009 | 02:33 PM
Tiny's Avatar
Tiny
Which U-joints did you replace did you check the ball joints when you were under it also did you take a look at the cardan joint to see if its dry or wore out?
Old Mar 16, 2009 | 03:05 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the front driveshaft Cardan joint for the squeak. Only thing is about that, it shouldn't squeak when in 2wd. And as asked above which u joints were replaced? The front axlejoints or driveshaft front or rear? The clicking sounds like front axle joints.
Old Mar 16, 2009 | 03:29 PM
TMS Bill's Avatar
TMS Bill
Any Ideas??
Not the driveshaft u-joints ... the single cardan u-joints ... at the ends of the front axle.
Old Mar 16, 2009 | 03:48 PM
zman17's Avatar
zman17
The double cardan joint will squeak if the ball and socket have gone bad, due to the dust shield and seal going bad. But like I said, it is not going to squeak in 2wd. So without knowing what joints were actually replaced , I'd put my money on the front axle joints too.
Old Mar 16, 2009 | 04:41 PM
dodgeram32's Avatar
dodgeram32
I replaced the front and rear driveshaft U joints/ the ball joints seem to be tight.
Old Mar 16, 2009 | 05:04 PM
zman17's Avatar
zman17
So the axle joints were not replaced? I say don't take it back to that place. BTW, How much did they charge you if you don't mind me asking.
Old Mar 16, 2009 | 08:23 PM
dodgeram32's Avatar
dodgeram32
Zman, I did not get the axle joints fixed. For 2 U joints and the labour it was about $220.00 (Can).
These sounds wouldn't be coming from the transfer case would they? just curious
Old Mar 16, 2009 | 08:35 PM
TMS Bill's Avatar
TMS Bill
The xfer case just sits there in 2wd so ... no, it's not that.
Old Mar 16, 2009 | 09:59 PM
dsertdog56's Avatar
dsertdog56
Sure sounds like front axle joints to me as well.
