Tranny Slippin
Old 04-07-2009, 09:55 PM
Steel Horse's Avatar
Steel Horse
Steel Horse is offline
Question Tranny Slippin
My tranny is slipping. I changed my filter and gasket and the kicking stoped. But continues to slip. Ive been told its my 2nd gear band needs to be tightend . If im in 3 or 4th gear and i punch it to kick into 2nd gear it slips at 2nd gear. Any ideas?? Im hoping i dont need an overhaul. I dont know the history on the truck. I just got it. But it has 142,000 miles on it? Whats wrong ???
Old 04-09-2009, 07:07 PM
dblj16380's Avatar
dblj16380
dblj16380 is offline
If its slipping in 2nd then it could be the governor pressure sensor and solenoid. Those are two common things that fail inside of our transmissions and that is part of what controls the 1st and 2nd shifting. First off I would try adjusting the bands though to see if that takes care of anything. There are plenty of threads on here about how to adjust the bands and how to change out the sensor and solenoid. I would start with the free stuff then go from there.
Old 04-09-2009, 08:41 PM
PurplDodge's Avatar
PurplDodge
PurplDodge is offline
My truck started to do this AFTER I adjusted the bands. Purpl is at the shop, I'll se what my tranny guy does.
Old 04-10-2009, 09:24 AM
Steel Horse
Thanks. I dont know if i want to risk tightning the bands my self. The shop will do it for like 100 bucks. I cant even seem to put on a new tranny filter and gasket with out it still leaking. But im hoping im needing an overhaul. The truck does have 145000 miles but i dont know any of the history behind it. Can a tranny on a dodge go that long with out an over haul? And dblji6380 GET A BRUSH GUARD SO WHEN YOU DO FALL ASLEEP AGAIN AND HIT A SIGN IT WONT DO NO DAMAGE...LOL
Old 04-10-2009, 10:40 AM
Ram2K1's Avatar
Ram2K1
Ram2K1 is offline
That stinks. I had been contemplating adjusting my bands next time I do a service, but I have heard a lot of stories just like yours about post-band adjustment malfunctions. Don't think I'm gonna do mine...just keep it serviced until it dies.
Old 04-10-2009, 11:04 AM
PurplDodge's Avatar
PurplDodge
Dont adjust your bands...........Dont fix what aint broken. Just change your fluid and filter every 15,000 miles.
Old 04-10-2009, 12:26 PM
Steel Horse
Why shouldnt i have the bands tighnted? it dosnt slip in anyother gear except that 2nd gear?
Old 04-10-2009, 12:45 PM
41canine's Avatar
41canine
41canine is offline
Default Adjusted bands
140,000 miles on trans and started ro slip and make a very quick 1-2 shift. Tranny shop wanted $1895.00 for a rebuild and $25.00 to adjust the bands.
I did the bands per the service manual, tightening to 72 INCH pounds and backing off 2 7/8 turns. Like a new trans. No slipping and no quick shifts. If it gets another year or so on it I'll be a happy camper. It's been over a month now and no adverse effects. There's some reason the manual suggest adjusting the bands every 25,000 miles.
Old 04-10-2009, 01:52 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
MonkeyWrench4000 is offline
Can a tranny on a Dodge go that long without an overhaul?
This must be your first Dodge LOL.
Your in for a a big disapointment.
JK JK.
Good Luck man!
Old 04-10-2009, 05:02 PM
Steel Horse
yup yup this is my first Dodge. Dam im only 19. Im learing the hard way. Ill temp to fix some things on my own. but when it comes to internal engine or tranny, uhh uhh..i aint touchin it.
Quick Reply: Tranny Slippin
