Has anyone tried these clear rear end covers??
Old May 3, 2009 | 12:04 AM
nolazach's Avatar
nolazach
Default Has anyone tried these clear rear end covers??
I thought they looked cool, a lot of rear end covers were in this price range.
The transparent covers not only look extremely cool when installed, but it also allow you to inspect for abnormal gear wear, oil levels, and for contaminants that could ruin your gears and shorten rear-end life. The polycarbonate material is the same material used in bulletproof glass, and is as impact-resistant as steel, but cleans easily with soap and water.
ClearGearz diff cover
I am having a hard time finding what I need for my rear end (drum backing/support plate) and may have to either buy a used rear or a $280 Stealership part. I keep finding knick knacks like this while searching for my part.
Old May 3, 2009 | 01:23 AM
engineblock's Avatar
engineblock
Thats pretty badass, i would like that if ti has the strength
Old May 3, 2009 | 01:28 AM
iwhitne's Avatar
iwhitne
pretty cool... if they only made valve covers like that!!
Old May 3, 2009 | 01:32 AM
Cereal Killer's Avatar
Cereal Killer
Yeah seriously. And transmission pans...
They're cool for sure. I don't think I'd get one purely cause i'd be scared I'd break it. If I never went off road I might... but I don't know how cool it would really look to see a bunch of gear oil.
Old May 3, 2009 | 01:50 AM
engineblock
I was reading there and they said that valve covers are on the way
Old May 3, 2009 | 02:15 AM
Maxx_Magnum's Avatar
Maxx_Magnum
wow man I've never even heard of clear rearend covers... that would look pretty cool to see drivin down the road....
Old May 3, 2009 | 08:01 AM
dhvaughan's Avatar
dhvaughan
i think those are perfect for dodge trucks. although, i don't think they'd stay see through clean for more than 5 minutes.
rear end cover - for easy inspection of broken LSD clips.
transmission pans - for easy inspection of broken OD snap rings.
t-case housing - for easy inspection of broken snap ring.
intake manifold - for easy inspection of leaking plenum gasket.
seriously, for your brake plates - have you tried LKQ, and local junk yards. all the junk yards share info, so your local guy should be able to find you one and get it shipped to him as cheap as anywhere.
http://www.lkq.com/
Old May 3, 2009 | 10:38 AM
BlueBeast2's Avatar
BlueBeast2
I still like the chrome covers better. Who wants too see brown **** spraying all over the place. I guess if you used a colored oil it might look cool
Old May 3, 2009 | 12:23 PM
Cereal Killer
That's kinda what I meant. The concept is cool. And it would look cool right after it was put on until you ran the truck once. Then that **** would be all over the inside of the cover, and it's so thick I bet you'd have to let the truck sit for days before it would be see through again.
Old May 3, 2009 | 12:25 PM
Cereal Killer
http://www.lkq.com/
Clear intake manifold eh? That might be asking for alot lol. Perhaps clear heads, or a clear block would be in order next? Although it would be cool...
