Old Aug 7, 2015, 12:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine
Print Wikipost
The $30 DIY Oil Change.............Flame On!!!!
Old May 19, 2009 | 10:38 PM
PurplDodge's Avatar
PurplDodge
I have never done that to an engine oil filter, but I do it to the external oil filter on my transmission.
Old May 19, 2009 | 10:42 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG
This is not a flame, but I have always laughed at the direction to tighten the filter 1 turn, 3/4 turn, etc. An old school mechanic taught me years ago (he hated the new fangled throw-away filters, btw) that you simply tighten the filter by hand as tight as you can get with one hand. Been doing that for 30 years and no leaks. I also coat the o-ring with Lubriplate or white grease even though they say not to do that, lol.
Old May 19, 2009 | 10:57 PM
Silver_Dodge's Avatar
Silver_Dodge
Ya, I just tighten the filter by hand. Never had a leak.
I'm not sure about the filter cross reference stuff. What do you mean "big filter"? None of those are the part numbers for the filters i use. I'd leave that out if I were doing this DIY. Just my opinion though.
Old May 19, 2009 | 11:06 PM
PurplDodge's Avatar
PurplDodge
Go through the "Bigger oil filter for 318/360-Cheap" thread. Thats why I used it.
Old May 19, 2009 | 11:58 PM
el_oso's Avatar
el_oso
OK, $10 PayPal to the person who spotted the huge mistake in this DIY.
Old May 20, 2009 | 12:05 AM
hutch1973's Avatar
hutch1973
He recommended going to wal mart for anything?
Old May 20, 2009 | 01:13 AM
pcfixerpro's Avatar
pcfixerpro
Forgot to pre-fill the oil filter? I fill mine up at least half before putting mine on.
Old May 20, 2009 | 01:50 AM
jasonw's Avatar
jasonw
Site Moderator
Well, he never said to put the pan under the drain plug, before you remove it, to catch the oil.
Side note, I've never needed a breaker bar. I've always used a normal ratchet or wrench, and always done fine. Only time I wish I had a breaker bar was after my father-in-law decided to let Walmart change is oil the previous change.
Anyone who uses an air tool for a drain plug should be taken out back and beaten just a tad.
Old May 20, 2009 | 02:46 AM
Laramie1997's Avatar
Laramie1997
1. He didn't mention checking to see if the O ring off of the old filter got stuck on the block.
2. Having to use a 16mm wrench on the drain plug, but that has already been addressed. (Mine is 5/8 too)
3. A 14 year old doing this procedure on a piece of machinery that he cant legally operate yet? (sry purpl, had to )
Old May 20, 2009 | 03:05 AM
jasonw's Avatar
jasonw
Site Moderator
Ah yes, that thing. I had forgotten about that. I always check it myself, only ever had it happen once (on my previous ride, a 1995 Dakota), but I know that the one time I don't look for it, it'll happen again.
