Fastman Question.
Have a question regarding the Fastman and I can't seem to find it via searches.
Got a 52mm from Dan this week, and can't be happier with the quick service. Emailed him around Wed saying I wanted one, he had it to me by Friday without any additional shipping charges. Put it on and it was simple enough, probably about a 45 minute job at the most, but not noticing anything different.
Just did the Superchips upgrade last weekend, which I definately noticed a change, but wondering if I need to do be doing something differently then his instructions regarding the pcm. I did unhook the battery and reset the pcm, drove it 40 miles or so to try to get it to relearn settings, but still can't seem to find a difference. Would actually say the truck has lost a bit from when I started.
Only read good reviews on the Fastman, so thinking I just don't have something quite right yet. Tips?
Think I need to do a test moreso then checking for oil with my plenum then. Post programmer, I could just break the rear tires loose by flooring it, not burn out contest, but just 'bump' them...now it won't even do that. If I was getting slightly better acceleration, thinking that would be at least the same? Am I missing something?
Sometimes a PCM reset make the truck really responsive and sometimes it makes it a dog. After a tank of gas it's almost always the same regardless of where it started on ht reset.
IDK why it does this, but it does. You could reset the PCM and drive it and it feel like a dog, and then reset it and it run like a bat outta hell.
I also noticed that you haven't really opened up the exhaust fully yet. Swap that factory cat with a Magnaflow or other high flow cat and make sure the pipe is a solid 3" from front to back and you should notice a nice bump in power.
Trending Topics
Something that hurts me is I don't drive the truck that much, so I don't notice subtle differences. Think AIM is right and my factory cat is probably limiting my exhaust system. I've done the mods up top with the 14x3 and now the fastman, so going to do that next and see how it works. Had been kicking around 1.7's for the next mod, so a cat is cheaper.
Dual 2.5's out the muffler or "fake duals" won't help a bit to open it up. The most restrictive parts in a stock exhaust are the Cat, muffler, and Y-pipe.
The stock muffler is a water heater, it's huge and stuffy. Specifically because our engines are some of the loudest on the market. Way louder than a Ford, Chevy, or Yota. They needed to make them sell-able to the average Joe who doesn't want to hear the engine all the time.
The Stock cat was built to last several years and the honeycomb inside of it is very tightly packed.
The Y-pipe is pinched tightly at the bends and really hampers some flow out of the manifolds. I'm looking to replace this soon, but a quality aftermarket one is hard to find.
It's also worth mentioning that the last few years of 2nd gens that the exhaust was expanded from 2.5" to 3" piping and the HP rating of the trucks was bumped up about 15HP.
It's something to think about.
