looky what came in today!
Old Jun 11, 2009 | 05:31 PM
  #41
BigRedRam95's Avatar
BigRedRam95
Put on my pulleys today but belt was 2 inchs too long so I am going to go and buy a new belt later
Old Jun 11, 2009 | 05:40 PM
  #42
Miami_Son's Avatar
Miami_Son
What's a belt latter?
No fair editing after the crime!
Old Jun 11, 2009 | 06:18 PM
  #43
dakotas ram's Avatar
dakotas ram
so you could put on the 136 and swap your old pulley onto it?
Old Jun 11, 2009 | 06:48 PM
  #44
aim4squirrels's Avatar
aim4squirrels
you might be able to do that, it would depend on whether or not the alt pulleys were the same diameter and bolt hole. If it's a different sized pulley, you'll get a different charge rate. The ground strap point and alt gauge plug might be different on the back as well, so don't assume it's plug and play.
Old Jun 11, 2009 | 06:51 PM
  #45
Laramie1997's Avatar
Laramie1997
When I got done with all my audio equipment, I had to upgrade the ALT. All I did was go to a Denso shop, and they built me a 170 AMP alternator. All I had to do was put a 200 amp fuse in the master, and nothing else. Been running it for 3 years now, and havent had a problem. They did switch out pulleys when they did it though. Ran me about $200 for it. Mine came stock with a 117 amp, and that wasn't enough for two amplifiers....
Aim, sounds interesting, but I think I would be a dumbass to use it on my setup....
Old Jun 12, 2009 | 09:14 AM
  #46
BigRedRam95
Also If anyone is going to put a underdrive kit on and it comes with a alt pulley leave the belt on when you take the nut off the pully so it will not turn. I tryed to do it like the DIY said but could not get it to come off. So I put the belt back on and hit it with the impact gun and it came right off. Just a idea might save you some time!!!
Old Jun 28, 2009 | 11:09 PM
  #47
dakotas ram
so do you have issues with the efan?
Old Aug 11, 2009 | 03:09 PM
  #48
yotaco_22's Avatar
yotaco_22
I just ordered the hughes underdrive pulleys (crank & altenator) Can I remove the crank pulley without taking off the balancer too (the center bolt). Also anybody know what size belt?
Old Aug 11, 2009 | 03:23 PM
  #49
dakotas ram
im pretty sure that you can remove just the pulley, i think theres like 4 bolts around the center one
Old Aug 11, 2009 | 05:22 PM
  #50
aim4squirrels
There were 6 bolts that held the pulley to the harmonic balancer on mine torqued to 200 in/lbs. The big center nut doesn't need to come off, at least not on the 5.2L. Call Hughes for the belt size they recommend.
