Transmission acting funny
#51
You don't want the check valve, period.
Old or new.
Check this thread
https://dodgeforum.com/forum/2nd-gen...ve-delete.html
Governor sensor install
https://dodgeforum.com/forum/2nd-gen...d-install.html
DIY, and keep the pressure on the sham mechanic.
On what grounds could he possibly refuse to honor a waaranty after only a couple weeks ?
Old or new.
Check this thread
#53
#54
i work at a muffler shop so im blessed with a hoist lol makes it a breeze i had the parts i had already figured that would be the problem but when i check the voltage coming out the computer for the solenoid im getting .76 volts when i should have five so im leaning towards a new computer
#55
got my pcm re flashed today from dodge they say everything is working properly i installed it now its only doing it occasionally and when it shifts to second it drops right back to first and then shifts back to second and works propperly man im lost now any ideas? i have searched all over the site and cant compare my problems im having now to anyone elses i need some help
#56
hey buddy i feel your pain i had my trans rebuilt 6 months ago an since the day i got it it does your latest prob shifts to second a couple times then goes in an works great threw all the other gears. i got a 1 year worrentee with this back yard guy he has been trying to solve this prob ever since my truck is at his place right now he put in a brand new valve body gov press sensor an an just about everything else. today he is going to apply press to my drums with his air tool to see if it holds press the dealership said it might have a bad o ring thats allowing the fluid to go up their but fall back out alowing it to come out an go back in to second. mine works fine under hard acceleration anything over 3 thousand rpms will yours work fine over 3 also. im lost an getting verry upset with this deff sorry if that truck is your dd i have srt8 charger i drive for my dd but this is still agrivating i want mu damn truck to work right an be back in my hands. if this last test proves to be not it he is rebuilding a nother dodge tranny he has at home an swapping it in.
