Read trouble codes without code reader?
Old Apr 4, 2010 | 10:10 PM
rideordie's Avatar
rideordie
https://dodgeforum.com/forum/2nd-gen...c-display.html
It works on all of our trucks. It worked on my 95 (OBD1) as well as my 01 (OBD2).
Start with the key off, then on but dont start. repeat 3x, and it will flash your codes on your odometer.
If OBDI, it will flash X number of times, then briefly pause, and repeat. when finished it will flash 5x.
If OBD2, it simply states the codes one at a time, ex. P1234
Old Jun 13, 2011 | 01:09 AM
kingnadda999's Avatar
kingnadda999
Default Same Problem
I have a 98 Ram 1500 and I cant get the odo to show the codes either
Old Jun 19, 2011 | 08:27 PM
klings designs's Avatar
klings designs
me either
Old Jun 19, 2011 | 10:11 PM
aim4squirrels's Avatar
aim4squirrels
Damn, double posted. See below.
Old Jun 19, 2011 | 10:12 PM
aim4squirrels
Try doing the "key dance" a little faster or slower. Make sure you go all the way to full on and off, and leave it in the on position.
Its been a really long time, but I think I recall a thread stating that some 98's did not have this feature, and I believe they narrowed it down via the VIN to those built at a specific plant. I can't recall all the details, been a long time.
Old Jun 9, 2017 | 10:38 PM
Nick Bain's Avatar
Nick Bain
my 98 also does not seem to work also it is made in mexico, maybe that is why?
Old Jun 9, 2017 | 10:50 PM
Key dance stopped working on the 98 models I do believe, regardless of where they were built. I think it came back later though?
Old Jun 10, 2017 | 08:07 AM
Moparite's Avatar
Moparite
It only works up to 97.
http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
Old Feb 21, 2019 | 01:35 PM
Robert Schmidt's Avatar
Robert Schmidt
Default Me too!!!
Originally Posted by Maxx_Magnum
well thats strange then..... anyone with a 98 that can confirm this works? I imagine it should...
I'm having the same problem my 98 mine is a 5.9 l V8 and I can't get the key sequence to read my codes I tried to push the trip button and hold it While doing the key sequence and still nothing
Old Feb 21, 2019 | 07:00 PM
Key dance doesn't work on 98 and newer trucks. Pushing the trip reset while turning the ignition on does a cluster test, and will give cluster codes, not powertrain codes.
