Question About A Tune Up
Old Aug 3, 2009 | 10:12 PM
Bob5151's Avatar
Bob5151
Default Question About A Tune Up
I'm getting ready to tune up my Ram's angine this weekend. I am going to change the oil on Friday night, since it's due this weekend anyway, and then do the rest on Saturday morning. I'm also doing plugs, wires, dist. cap, rotor, and pcv valve. Should the engine be cold or warm when I do this? Should I let it sit over night and just start in the morning, or start it up and let it run for a few minutes before I start? Any help would be appreciated!
Old Aug 3, 2009 | 10:25 PM
dhvaughan's Avatar
dhvaughan
do it all cold. although the oil is cool and thicker, its all drained down into the pan, and its not hot when handling it. as far as tune up - also cold. its very unpleasant trying to work on a hot motor.
Old Aug 3, 2009 | 11:36 PM
PurplDodge's Avatar
PurplDodge
When doing the tune up: cold.
Oil change: Warm, not hot. Run your engine at idle for 5-10 minutes to get it warm.
Old Aug 4, 2009 | 01:11 AM
dodge15004x45.9's Avatar
dodge15004x45.9
I drive around for a little than let it sit for like 10 min than drain the oil and let it drip for like 10 min.
Old Aug 4, 2009 | 06:48 AM
Bob5151's Avatar
Bob5151
Thanks guys. I was mostly referring to the plugs and all, not so much the oil. I've done many oil changes on mine and my friends' cars, but this is the first time I will attempt a tune up. Thank you for the help, much appreciated!
Old Aug 4, 2009 | 07:20 AM
dodge15004x45.9
Do you have any parts picked out for plugs etc?
Old Aug 4, 2009 | 07:32 AM
2damnyankee's Avatar
2damnyankee
hope you have a body lift so you can reach the cap or really small hands. good luck your fingers are going to get a work out today
Old Aug 4, 2009 | 01:30 PM
Bob5151's Avatar
Bob5151
I haven't picked out the parts I want to use, I'm just going to do a search and find out what people have had good luck with. I don't have a lift, and I have looked, and the distributer is really way back there. I'm definitly taking the air cleaner box off, are there any other little tricks for getting the wires, cap, and rotor out?
Old Aug 4, 2009 | 02:30 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
A tune-up? No such thing with these trucks.
Old Aug 4, 2009 | 08:39 PM
PurplDodge's Avatar
PurplDodge
Champion plugs are what is recommended. For a good set of wires you can get MSD Street Fire 8mm plug wires for $40 @ AutoZone. For a cap and rotor get a Brass NAPA cap and rotor. Getting the cap and rotor off with the air cleaner is the only way to do it.
