Fog light mod
#21
In some states you are only permitted to have no more than 4 forward facing lights turned on. Still dumb to me. My 98 has 2 fog light relays and the DIY didn't work for mine.
#22
In CA, any lights other than the stock headlights or a set of foglights must be covered while the vehicle is operated on the road. You can be ticketed even if they aren't operational.
#23
For even more lighting...we need to figure out how to run high and low beams at the same time. You get a brief glimpse of this every time you switch high to low or vice-versa. Or you can keep it there for a short while by holding the switch inbetween high and low (all four stay on as long as you hold the switch...my only concern is the temperature inside the headlight if it was made permanent.
#24
My 97 is the same way. Would it work if both relays were jumped?
I'd also be worried about the power draw through the stock wiring.
#25
All vehicles have the high beam killed if the fogs are on, it's probably a Federal requirement. Since mine are after market I don't have the problem, but I haven't been out in the boonies in a while so I haven't had a chance to need both. A few years ago we went to the Grand Canyon and was caught making my way back to Flagstaff at night, and it gets so dark out there, it looks like you are driving in a black hole. I didn't have my fogs at that time, and the high beam was barely enough to see the road.
As for temp, I agree that would probably get hot. My after market fogs get so hot, I don't use them unless I know I will be moving (Freeway only, not city driving). I don't want to chance them melting the plastic housing in the bumper.
#26
on
sorry to hear the diy didn't work for y'all. try pulling one relay and see if you only have one fog light turned on. if that's the case then i don't see why it would hurt to jump them both. keep in mind that I'm not an electrical guru, I'm just passing on what I've seen two other guys post before and that it worked for me with my 2000 ram. so don't risk burning anything up if you're not sure about what you are doing.
i looked at the relay in my center console this morning and saw that the jumper wire closes the circuit between the 30 and the 87 connections. the 30 and 87 are an open circuit until you energize the 86 connection. so what this jumper does is make the 30 (from battery) and the 87 (goes to the lights) a closed circuit all the time. so when you turn on the fog light switch it puts power to the lights the whole time the switch is activated. i don't see how this would hurt anything because when you have the fog lights turned on the 30/87 are connected. i believe the only reason for the relay is to deactivate the lights when the high beams are turned on.
#27
Wondering if there's any way to do this for my 95 it came with stock fog lights that look like projectors. When i go under the hood there is no relay just a fuse. Mabe the switch under the dash has to do with it cause its a pretty big switch
#30
True. My fog light bulbs are burned out right now. Taking my time buying new H3 bulbs. Then I'll experiment with the relay jumping in my 97. It's not that big of a deal because I want to get large driving lights (Hellas or equiv) to mount on my push guard. Need lots of lights at night around here in the mountains.
