Removed TB spacer...WOW!
Old Sep 29, 2009 | 10:16 AM
AlabamaRam95's Avatar
AlabamaRam95
Default Removed TB spacer...WOW!
alright heres how it goes...
i installed a CAI and the TB spacer at the same time. i was so happy that i finally got it and about the way it looked that i guess i tricked myself into thinking that it helped.
WRONG!!!
i removed the TB spacer last night and i was amazed! throttle response is 100 times better and it even idles better. Who would have thunk it...lol.
however, the bottom side of the butterflies, the TB spacer, and the entire inside of the intake is covered in a disgusting, greasy, oily, sticky, black gunk.
is this normal? why is it there? is it hurting anything? what can i do?
Old Sep 29, 2009 | 10:19 AM
Aubrey's Avatar
Aubrey
You have a plenum gasket leak. Get a new intake or just the plate from Hughes. There's lots of stuff here on the issue.
Old Sep 29, 2009 | 10:31 AM
AlabamaRam95
i figures that was the problem. i have been doing a lot of reading here about that plenum leak problem.
is this something that i can do in a day?
Old Sep 29, 2009 | 10:44 AM
Oren09's Avatar
Oren09
If you have the parts and tools, and decent experience using them.
Old Sep 29, 2009 | 11:34 AM
AlabamaRam95
that i do
Old Sep 29, 2009 | 11:46 AM
95MaroonMonster's Avatar
95MaroonMonster
yea, TB spacers on these trucks are better used as paperweights
Old Sep 29, 2009 | 12:05 PM
cmckenna's Avatar
cmckenna
Hmmm. They are supposed to prevent the intake heat from reaching the TB and, on my Hughes FI, it works. The TB remains cool despite the intake being very hot.
Now, if the riser block was leaking at the gasket areas, then, surely that would have a negative effect on performance thus giving the user the impression that it works better w/o one when in fact, the real issue was a leak at the intake and TB interface.
The other area of concern is how well the gasket is trimmed to the port opening and whether or not there is an overhang of gasket material in the opening thus impeding air flow.
Old Sep 29, 2009 | 12:11 PM
dakotas ram's Avatar
dakotas ram
it may keep the tb cooler, but there is no fuel going thru it so its pointless
Old Sep 29, 2009 | 12:12 PM
95MaroonMonster
yours works b/c the Huges intake is a different design than the kegger is, it no work with the keg
Old Sep 29, 2009 | 12:18 PM
cmckenna's Avatar
cmckenna
Oh, he's talking about when using one with the keg style? Gotcha. Agreed.
