Trans problem
Old Oct 1, 2009 | 05:59 PM
318Ram4x4's Avatar
318Ram4x4
Default Trans problem
I have a 1995 dodge ram 1500 4x4 5.2L(318) and it is in limp mode. I washed the truck after i took it off-road. I didn't wash it till a day after i went wheeling. i cleaned the terminals, changed the tp sensor, and checked the other sensors that i can see. what can it possibly be?
Old Oct 1, 2009 | 06:08 PM
Aubrey's Avatar
Aubrey
Describe what you mean by limp mode.
Mine went into limp mode when I didn't get the speedo gear back in right.
Old Oct 4, 2009 | 08:11 PM
318Ram4x4's Avatar
318Ram4x4
I take my truck off roading and it was fine for a couple days after i went out one day. after i wash the truck, it will not shift. its weird. it will not shift out of first gear.
Old Oct 4, 2009 | 08:29 PM
dhvaughan's Avatar
dhvaughan
i don't know if this applies to your 95 or not, but my old chevy used to not shift whenever the vac line to the transmission was off or leaking.
Old Oct 5, 2009 | 11:18 AM
Aubrey's Avatar
Aubrey
Start checking your linkage and connectors on your tranny and t-case.
Old Oct 5, 2009 | 11:25 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Sounds like the speed sensor on the TC.
Old Oct 5, 2009 | 01:31 PM
318Ram4x4's Avatar
318Ram4x4
the speed sensor on the transfer case can make it not shift? thats a first ill try that.
Old Oct 5, 2009 | 01:46 PM
zman17's Avatar
zman17
Yup, Make sure the wire didn't pop off or the connection is not corroded.
Old Oct 5, 2009 | 02:20 PM
Augiedoggy's Avatar
Augiedoggy
could also be the govenor pressure solenoid or the transducer...mine went into limp home mode and I replaced those to fix it.
Old Oct 5, 2009 | 03:10 PM
318Ram4x4's Avatar
318Ram4x4
i just replaced the speed sensor and checked the wires. that did not fix the problem. i thought it was the govenor pressure solenoid also just didnt change it. i dont know were to order one from and i dont want to go to the dealer and get it.
