Overhead console upgrade
Old Nov 1, 2009 | 09:46 PM
  #41
2001Ram's Avatar
2001Ram
Does ET stand for Elapsed time? Every time Id restart the truck it would restart itself. So, I need to check the ground. I am pretty sure I had everything run correctly (except for the ground) because 2 wires bumped together and thats when it shut off. I replaced the fuse tonight, all good there. There is I ground off of the Brown plug that I didnt hook up, so that must be my problem. I will try again tommorow and see.
Also, I tried the Merry Christmas thread and found the overhead console diagram. It didnt help at all. I must be on the wrong page or something. Do any of you guys know which page I need for the wiring colors and function?
Thanks a million!
Ryan
Old Nov 1, 2009 | 10:01 PM
  #42
004x41500's Avatar
004x41500
glad you got the radio and everything fixed, but i can no longer help, since im limited on knowledge of tje console. good luck though.
Old Nov 1, 2009 | 11:27 PM
  #43
2001Ram's Avatar
2001Ram
Anyone else know?
Old Nov 9, 2009 | 02:22 PM
  #44
notanexit7's Avatar
notanexit7
umm, i didn't have to do this upgrade seeing as how my truck came with the overhead console but i do have a question. Does anybody else have to reset their console every 2 weeks or so? I'll be driving down the road, console says i'm getting 18 (which is wrong btw, I'm getting 15) and then when I park and turn the truck back on sometimes I'm getting 64mpg with 999 miles to empty at a full tank ( I wish)!! I'm not sure why it does this and why my mpg's are wrong even after resetting it.
Old Nov 9, 2009 | 11:22 PM
  #45
2001Ram's Avatar
2001Ram
Mine says I am getting 5.5 MPG. Dodges are bad, but not that bad. I get about 12.5 MPG. I still cannot figure out why my temp. to work. Its so frustrating.
Old Nov 10, 2009 | 07:52 AM
  #46
notanexit7's Avatar
notanexit7
haha yeah I know its irritating. everything else works great, compass and temp, just I wish it would stop with the false illusion of 64mpg's.
Old Feb 1, 2010 | 02:08 PM
  #47
koaea's Avatar
koaea
Default How many people have done this now?
Seems unfortunate that the links to these pics have changed or something. My console/harness should arrive from ebay in about a week, and I think the pics would have been very helpful!
Joe
Originally Posted by working4ev
After looking and asking if this could be done i finally bit the bullet and bought the digital overhead console from ebay.
This is how i converted my 2001 Dodge 1500 4x4 non-digital to fully digital overhead console hope this helps someone.
Common misconceptions: you need to remove the dash to do this (NO). You need a trip computer (NO) It is not possible (NO NO)
what you will need
the overhead console for your year 97 or later use a different wiring harness and the plugs are in a different place.
If you get a console with all the plugs, installation is simply plug and play. There should be 4 plugs -- 1 For the console, 1 For the rear view mirror, and 2 That plug into the truck.
If your console comes without the plug that plugs into the truck you will need KK Standard Crimp Terminals (See picture), also Electric butt connectors.
Now to the removal and install
Remove the old console from your truck
To do this open the garage door opener compartment you will see two tabs. Push both of them and pull down a little, now push the whole console back (towards the rear of the truck). This will release the console from the truck. Remove the power plug from the console.
Remove the 4 screws holding the sun-visor and that little clip the visor clips to.
Remove the drivers side pillar cover just pull it off (it has clips on the underside).
Pic was taken after I removed the wire but you get it.
Now you can pull the headliner down, here you will see the wires for the console
Again took the pic after i removed the wires.
Now the fun part: the wire for the overhead console runs down the side of the dash on the side pillar down to the back of the fuse panel. It is the only brown plug on the back of the box. Tip: remove the panel under the steering wheel and lay on your back with your head resting on the E-brake and look up through the wires with a light.
To plum the wires for the new console, take the old one and tape one end to the end of the new one making both harnesses one. Now pull the old one out with them taped together this will pull the new one through the same route the old one was. Trust me this is the easiest way. Now just plug it into the fuse box as the old one was.
This will give you power to the lights, and the digital read out but the Trip, compass, and temp sensor will not work (yet) -- It will say CCd on the readout.
The temp sensor wiring is under the hood right next to the wiring for the under hood light
If you have the plug for the sensor, plug it in and run the wires up the drivers side around to the front of the grill and bolt down.
Hooking up the temp, compass, and trip:
Look under the dash you will see a white plug
This plug feeds the info needed to run the temp, compass, and trip.
I just cut the wires and used 2 butt connectors, just match up the colors to each other
Now turn on the ignition and see how good it works
If your temp is like mine in Celsius & kilometers you can change that
Temp first with the read out on the temp and direction push both buttons it will switch.
It is the same for the KL to Miles.
FYI If you need to wire the plug that plugs into the fuse panel hear is how.
here is the back of the junction box C3 is the brown plug for the overhead console
#1 Black / Light Blue
#2 Black / Light Green
#3 Yellow
#4 Nothing
#5 Violet / Light Green
#6 Pink
#7 Nothing
#8 Nothing
#9 Nothing
#10 Nothing
#11 Violet / Black
#12 Nothing
#13 Black
#14 Dark Blue / Wight
You will need KK Standard Crimp Terminals
Thank you to
PurplDodge for the help
steve05ram360 for the 2nd Gen Service Manual Download - AKA merry Christmas thread this manual was a big help
Hope this helps
Old Feb 1, 2010 | 02:54 PM
  #48
Miami_Son's Avatar
Miami_Son
Sorry, but we have no control over them. If a member later deletes them from their pic host account then the links will be broken. There's nothing we can do to fix them since the pics are never on our servers to begin with.
Old Feb 1, 2010 | 05:15 PM
  #49
PurplDodge's Avatar
PurplDodge
I really hate it when that happens.
Old Feb 1, 2010 | 05:59 PM
  #50
Sheriff420's Avatar
Sheriff420
it's always a photobucket picture also, hmm...
