Can You Level your 2WD with a Body Lift?
Old 10-30-2009, 08:55 AM
gobbell1's Avatar
gobbell1
gobbell1 is offline
Default Can You Level your 2WD with a Body Lift?
I recently installed the DAYSTAR 1.5" leveling kit on my '96 2WD. While I'm pleased with the looks, I'm not impressed with the change in ride quality (much harsher).
So I was wondering if I could put a body lift on my truck that would a) lift the truck 3" and b) level the front end as well. Then I could remove the polyurethane donuts from DAYSTAR and return to a better ride.
Old 10-30-2009, 09:38 AM
Twisted Metal's Avatar
Twisted Metal
Twisted Metal is offline
Nope, its either or. The Daystar kit raises the front suspension to match the factory rear height. So just a body lift with no leveling will still have the rake, just 3 inches higher. One alternative would be install 2 inch drop shackles, then install the body lift. The rake look the Rams' have is suspension, not in the body.
Old 10-30-2009, 10:14 AM
dakotas ram's Avatar
dakotas ram
dakotas ram is offline
yeah, i have drop shackles on mine and there was no change in ride quality, im fixing to put on 3" lift springs in the front tho......
Old 10-30-2009, 10:42 AM
Twisted Metal
Whoa WHO IS THAT DAKOTA!??! HUBBA HUBBA!
Old 10-30-2009, 11:08 AM
dakotas ram
g/f......
Old 10-30-2009, 11:38 AM
Weldor's Avatar
Weldor
Weldor is offline
So you guys are basicly lowering your trucks just to lift them? Why not just run the leveling kit with the body lift and get more lift out of it...
Old 10-30-2009, 11:48 AM
Twisted Metal
Weldor I agree 100%. But the OP complained about a harsh ride.
Dakota.... very nice my friend
Old 10-30-2009, 12:04 PM
dakotas ram
the only reason i have the shackles on back, is that i originally planned on lowering it, after i get my front lift springs on, i will then decide if i want the back put back to stock or go with a prerunner look.....even with the 2" drop in the rear, my front is still about 2" lower
Old 10-30-2009, 12:05 PM
dodgeram07's Avatar
dodgeram07
dodgeram07 is offline
did you put in longer shocks??? for the exrta 1.5 in?? if you get longer one it will ride better
Old 10-30-2009, 12:40 PM
dakotas ram
yeah, people tell others that stock shocks are good for 2" lift, but i think you need longer ones anyway, esp. if yours are the same ones that rolled off the assembly line
Quick Reply: Can You Level your 2WD with a Body Lift?
