Control Timer Module (CTM) Issue?
#21
ok, well I replaced the Time Delay Relay, and I still don't have any Map lights or Dome lights when the door opens, the only time I can get the dome or map lights to come on is by turning the **** on the headlight switch, I went through both fuse blocks and tested every fuse. and like i said previously the chime works when the key is in the ignition and the door is open, but no light.
also on the power block under the hood, I saw a fuse for fog lamps, but I don't have any fox lamps on my truck none the less a button for it.
anyways off topic. any more suggestions, the next thing im going to do is replace the door jam button.
if anyone has any other suggestions please let me know, this is agitating when I can see to get into my own truck at night.
#22
#23
as well as seat belt alert and so on.
I am going to try and replace the headlight switch.
#24
#25
#26
#27
