Head Light Conversion
Hello all....
I find myself wanting to do the sport headlight conversion on my 99 ram SLT. My headlights are shot, the plastic is foggy and old. I know they can be cleaned but the trucks is 10 years old and they are the original lights. I was searching for some new lights on ebay and parts store's then thought i would come here and see what folks are saying about new headlights. I ran into a few threads about converting the standard lights to the Sport model lights. I'm pretty sure i like this ideal... the problem? every thread i find on doing the conversion is "years" old and point to other links that are long gone.
So what i have gathered is my truck has only on bulb, the sport has two. My harness will need to be modified. I noticed that LMC has a harness. Does anyone know if the harness from LMC just plugs into my old harness and ta-da i have two bulb sockets now? Do the lights themselves fit or do i have to cut some metal out of the truck?
Just looking for some "current" information about this mod.....
thanks for any help you can provide...
Jake
Jake
Yours is like mine. The old sports only had color matching grills, and bumpers.
Trending Topics
Ok so from what I have found so far is that you will need to cut out the headlight bucket a bit to make room for the access to the 4 bulb setup. At suvlights.com you can order a whole harness for around 133 bucks. It supposedly comes with relays and the harness. So I hope this helps. I found a writeup about it on
http://www.cumminsforum.com/forum/94...onversion.html
This one was on a 96 but I would imagine it would be about the same till the 02 models when the whole truck changed.
go on ebay but clear head lights and then buy a HID head light kit i spent about 155 for my head lights they were clear and had clean parking lights.. and then i spend about 100 on HI/LOW HID kit 9004/9007 temp 6000k they are very bright and they are amazing on dark roads fog and actaully anything they are street legal as well( well in washington state they are) i spent about 255 total for the ehad light up grade... plus you can also up grade you fog lights with HID fog lights as well they will run you about 80 dollars they also make a big help too... i got all my stuff off ebay and i'm very very happy with it all
