What is this hose on my axle?
Old Nov 8, 2009 | 02:31 PM
2001Ram's Avatar
2001Ram
Default What is this hose on my axle?
I heard a dragging noise when I was leaving my driveway the other day, got out and saw this on the ground. Anyone know what its for and where its supposed to be? I hope its not really important.. lol
This is where its connected to the axle.. I have no idea where it goes.
Old Nov 8, 2009 | 03:01 PM
Laramie1997's Avatar
Laramie1997
Hmm... No pic...
More than likely, it's the vent tube, and unless you plan on submersing your axle in water, not that big of a deal. course, wont know fr sure with out a pic...
Old Nov 8, 2009 | 03:33 PM
95RAM360's Avatar
95RAM360
2 or 4 wd?
and is it the actuator if its a 4x4?
and like stated above theres no pic
Old Nov 8, 2009 | 03:43 PM
Miami_Son's Avatar
Miami_Son
Red Xs. Would help to know which axle you're talking about.
Old Nov 8, 2009 | 03:51 PM
dhvaughan's Avatar
dhvaughan
rubber tube about 3/8" dia ? vent tube. should be a little check valve thingy in the end to keep the water out. then just wire tie it up as high as it'll reach with slack for axle/body to bounce up and down.
Old Nov 8, 2009 | 03:56 PM
2001Ram's Avatar
2001Ram
Strange, its a 2wd truck. I can see the 2 picts perfectly. Let me fix it.
Old Nov 8, 2009 | 04:01 PM
dhvaughan's Avatar
dhvaughan
since you can see the pic and we can't, its because of login/sharing permissions set on the hosting site. vent tube is on all differentials - rear (2wd and 4wd) and front (4wd)
Old Nov 8, 2009 | 04:03 PM
95RAM360's Avatar
95RAM360
yea just tie it up. mine is. now that i can see the pics, i have the same thing. just zip-tied it up to the frame
Old Nov 8, 2009 | 04:43 PM
Miami_Son's Avatar
Miami_Son
Might want to add 2WD to your profile info. That hose is the axle breather tube. The hollow bolt it is mounted to serves two purposes. It vents the axle through that hose and mounts the brake distribution block to the axle tube. Looks like the zip tie failed and the hose fell down. Just zip tie it back up.
Old Nov 8, 2009 | 09:51 PM
aim4squirrels's Avatar
aim4squirrels
That's the emergency catheter tube for that long trip home after the strip club.
