Rough running issue
Old Dec 10, 2009 | 04:14 PM
  #21
972500V8's Avatar
972500V8
I havet done much to it yet, ive been busy and it being so cold i dont have a garage i can fit in, and im broke, tomorrow im gonna get a new O2 sensor and plugs and do that and see what happens and check everything over in the engine compartment.
Old Dec 11, 2009 | 09:29 AM
  #22
972500V8's Avatar
972500V8
Well tonight im gonna replace the O2 sensor and do the plugs, wires, cap and rotor.
Can someone tell me which O2 sensor is Bank 1 Sensor 2
Old Dec 11, 2009 | 09:53 AM
  #23
DODGEPWR's Avatar
DODGEPWR
Make sure you rout the wires according to the TSB
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Old Dec 11, 2009 | 10:05 AM
  #24
972500V8's Avatar
972500V8
Thanks a lot, do they have anything like that for the O2 sensors, i need to figure out which sensor is Bank 1 sensor 2
Old Dec 11, 2009 | 12:41 PM
  #25
rydesolow's Avatar
rydesolow
Let's break it down. The bank refers to which head it is monitoring. So in your case, Bank 1 would be the side with cylinders 1,3,5,and 7 on it. The sensor one, is upstream engine monitoring(before the cat), or two, downstream cat monitoring(after the cat).
So the conclusion is: Bank 1 sensor 2: Passenger side, Behind the Cat.
Hope this helps. Be sure to check your wires and grounds before replacing the sensor. The sensor will show code for many reasons. Out of range voltage, shorts, etc.
Old Dec 11, 2009 | 12:43 PM
  #26
rydesolow's Avatar
rydesolow
I'm hoping your CAT hasn't gone bad That would cost some good money..
Another method to see if it's broken: Grab the CAT when cool, and shake the daylights out of it. If you hear rattling or anything flying around inside... It's time to be replaced.
Old Dec 11, 2009 | 01:22 PM
  #27
972500V8's Avatar
972500V8
if the cats bad im just gonna cut it out and just weld in some tubing.
Old Dec 11, 2009 | 01:38 PM
  #28
rydesolow's Avatar
rydesolow
That will work. I had to do that to my Jeep. Not sure if your O2 sensors will read wrong after that, I'm not sure on a Ram. If it pops codes, just get an O2 simulator. I think their only $20 off ebay.
Old Dec 11, 2009 | 01:43 PM
  #29
972500V8's Avatar
972500V8
So like you said the O2 sensor i need to change is on the passanger side behind the cat, would that one though the truck off like that.
Old Dec 11, 2009 | 01:46 PM
  #30
rydesolow's Avatar
rydesolow
It's possible.. but it's unlikely unless it's shorted out to cause big problems like that. If the cat is truly clogged, it will make your truck run like garbage.
The O2 sensor helps the computer determine how much fuel to inject into the cylinders. (Air/Fuel ratio)
If it's running too lean, it will run a bit rough.. Too rich, you'll probably be blowin smoke out your pipes..
