my build list... with prices
ok guys i know i cant do a built up for he truck, but i figured the least i could do was get you guy a price and build sheet for what ive done to my truck... so here it is... now keep in mind these are all lower prices cause i put in the retil on everything, and didnt include any shipping, or taxs....
front and rear dana 60's------------------------------------------------------------750( BIG STEAL)
custom shafts llc driveshafts----------------------------------------------------400
dick cepek long arms----------------------------------------------------------------600
skyjacker etreme drop pitman arm---------------------------------------------200
skyjacker front coil springs--------------------------------------------------------220
dtprofab tracbar------------------------------------------------------------------------430
daystar coil spacers-----------------------------------------------------------------130
bilstian 5175 offroad racing shocks---------------------------------------------280
custom rear leaf springs------------------------------------------------------------470
tough country aal springs-----------------------------------------------------------100
bds shackle flip-------------------------------------------------------------------------250
ord zero rate-----------------------------------------------------------------------------150
new ubolts---------------------------------------------------------------------------------50
procomp series 52 16X10 8lug rims---------------------------------------------420
37X12.50 Super Swamper SSR tires------------------------------------------1400
head lights tail lights and third brake light-------------------------------------400
new grill and front bumper-----------------------------------------------------------400
posilock cable----------------------------------------------------------------------------210
skyjacker trasfer case index ring-------------------------------------------------295
Vinyona speed shop TRANSMISSION W/cooler--------------------------1080
pacesetter shorty headers and magnaflow hiflow ypipe and cat-------380
1ton steering box-------------------------------------------------------------------------300
all = up to about 8830 or something like that... so i just say i got 9k invested into this truck.... for it to look as good as it does...
now there are always things to come... the next few things that are going on the truck,... is i am replacing some body parts... getting the body almost dent free if i can... and then getting it repainted white again with the black grill and bumper... from there i have my 2inch tubing that i am going to make some sliders out of for the doors and cab even though i don't think i will ever hit them on anything... and then a set of skid plates will be made for this truck because i know myself... i am going to get high centerd on a hill somewhere case i think i sit high enough... and at the same time i am pulling the interior and possible roll cage when i do the rhino lined floor boards and then bolting diamond plate as permanent removable floor mats...
by the time i get that done the tires will start to wear down and i will need to add the 3inch body lift and maybe cut some fenders and fit some 41s under it... rework the sliders... and shold be about done with the truck untill i can get something else to play with... and this truck will be a recovery truck...
Last edited by meanwhitemopar; 12-10-2009 at 08:52 AM. Reason: one of my lines were off
i want long tubes... how can i do long tubes and true duals... remember i have to have emissions comliant... so ihave to keep o2's and that means a cat.... so how can i?
![Name: twist.jpg
Size: 29.8 KB](https://dodgeforum.com/forum/attachments/2nd-gen-ram-tech/95295d1501394660-my-build-list-with-prices-twist.jpg)
this was with the stock ram front and no shocks... i can go more then this right now.
![Name: twisteed.jpg
Size: 34.0 KB](https://dodgeforum.com/forum/attachments/2nd-gen-ram-tech/95296d1501394660-my-build-list-with-prices-twisteed.jpg)
again with stock front shocks... so its limited on drop and up travel
![Name: sittintaller.jpg
Size: 67.5 KB](https://dodgeforum.com/forum/attachments/2nd-gen-ram-tech/95297d1501394660-my-build-list-with-prices-sittintaller.jpg)
this is how the truck sits now....about 10 inch lift and 37 inch tires.. i can fit more, but i didnt know that at the time...
![Name: twist.jpg
But, like you said, thats without shipping or taxes. Shipping alone will put you above $9k.
To stay emissions compliant with true duals, you'll need two cats, probably with two O2 sensors pre (one per cat), and two O2 sensors post (one per cat).
However, some emissions laws won't let you have more cats than what you came with from the factory. It depends on how strict North Carolina can get.
Trending Topics
yea, i knew they were pacesetter, however, i wish i got the ceramic coated ones now, because mine are starting to slightly rust around the bolts and whatnot. not that big of a deal, that kinda thing is bound to rust anyway. just like the stock manifolds. personally, i like the setup i have right now. just enough power on both ends to satisfy my needs so i'm happy.
with the duals, you're more than likely gonna have to do custom work regardless to get it installed. you can buy H-pipes already pre-assembled and just slap it together. you'll just have to figure out where haha.
