Front wheel flew off at 75mph!
Old Jan 3, 2010 | 09:54 PM
huttbutt's Avatar
huttbutt
Angry Front wheel flew off at 75mph!
Hi to all, has anyone else ever had thier wheel/roter/caliper fly off? It happened to me years ago in my 79 Power Wagon, and again today in my 99 Ram.WTF?
Old Jan 3, 2010 | 10:02 PM
primus454's Avatar
primus454
Wrong forum, a mod will probably move it for you.
I had my rear tire come off doing about 15 at the local shopping strip. Apparently it is a somewhat common problem with aluminum rims. If it isnt't put on just right, when it is set back down the rim shifts leaving one or more lugs loose. Shortly after they rattle off and then the tire follows shortly after.
Seems like you are okay, thats good to know!
Old Jan 4, 2010 | 12:57 AM
dakotas ram's Avatar
dakotas ram
theres been a couple of diff ones on here that i can recall
Old Jan 4, 2010 | 12:59 AM
2001Ram's Avatar
2001Ram
Take a couple of pictures PLEASE! Id love to see it! did it destroy the torque box and door?
Old Jan 4, 2010 | 01:05 AM
dakotas ram
torque box?
Old Jan 4, 2010 | 01:29 AM
Cheat's Avatar
Cheat
Originally Posted by dakotas ram
torque box?
Trans, Or motor would be my guess on that. Most likly motor though.
Old Jan 4, 2010 | 01:30 AM
2001Ram's Avatar
2001Ram
torque box?
I own a Mustang.. lol
"On perimeter frames, the areas where the rails connect from front to center and center to rear are weak compared to regular frames, so that section is boxed in, creating what's known as torque Box"
Old Jan 4, 2010 | 02:11 AM
lblair04's Avatar
lblair04
He said the rotor and everything flew off, not just the tire/rim...which would mean the the hub/bearing assembly grenaded most likely. If the bearings in the hub get worn out and lose grease or burn up the grease, it will get so hot inside that when you take it apart it looks like welding slag. Have you had any play in your front tires? Moving up down, in/out? This is common when it doesnt get caught and replaced
Old Jan 4, 2010 | 05:58 AM
95RAM360's Avatar
95RAM360
^my wheel bearings are bad,and it looks like my tires going to come off soon.
Old Jan 4, 2010 | 07:24 AM
wewanaplay's Avatar
wewanaplay
Wheel came off mt V.W. Bug one time, we were going around a long sweeping downhill turn @ about 50 when the LR wheel came off, my wife said "whats that noise" And as the wheel rolled past us I told her it was that tire that's not supposed to be way over there. we both startrd laughing our asses off till it crashed through someones glass patio door.
