Engine question on my ram
Old Jan 7, 2010 | 01:22 PM
Ramulator's Avatar
Ramulator
Default Engine question on my ram
Hi, i have a 96 1500 4x4 with the 5.9 motor..... i want to rebuild a motor in my spare time to drop in the truck later, problem is i have never rebuilt a motor and this is how i plan to learn like everthing elese i do , i need to know what motors will bolt into my stock setup (5.9 liter). I want more power so thinking an older 360 rebuil or a 340 small block ?? will the newer hemi 5.7 liters fit in my truck ?
thanks
p.s anyone know what my rear end gears might be , stock . It will take posi sometimes in dirt ect.. ?
Old Jan 7, 2010 | 01:28 PM
PurplDodge's Avatar
PurplDodge
A 2.2l 4cylinder from a Chevy S-10 will fit. Point there is that anything fits.
You cannot use an older LA small block engine. They are not the same as our Magnum engines. My advice is to go to a junkyard and get a 360 out of a 96 Ram, Dakota, Grand Cherokee, Ram Van, whatever and re-build that. If you are building for torque, I'd stroke it out to 408 or 426 ci.
Hemis are overrated. Too much wiring to make it run right.
For the gears, look at the sticker on the hood, right next to the latch.
Old Jan 7, 2010 | 01:40 PM
Ramulator's Avatar
Ramulator
What do you mean by "stroke it out" .....specifically.
Is there any differnt heads that will bolt on to increase proformance as well .
Old Jan 7, 2010 | 01:48 PM
halfamil's Avatar
halfamil
Some of guys put R/T heads on.
Old Jan 7, 2010 | 02:15 PM
PurplDodge's Avatar
PurplDodge
Increase the stroke of the engine.
Iron Ram heads from Hughes Engines are great heads. They also sell stroker kits.
Old Jan 7, 2010 | 02:38 PM
95RAM360's Avatar
95RAM360
you have 3.55's in the rear if they havent been changed
Old Jan 7, 2010 | 03:09 PM
Ramulator's Avatar
Ramulator
Ok so i find an old 5.9L motor and strip it and dip it, and bore it ... aside from the aftermarket heads what else can i do for proformance .... the cam ...i know nothing about it, what type cam would be best , racing cam maybe ? or something in between ? I want more power / torque but also don't want a 10 mile to the gallon rig.
Old Jan 7, 2010 | 03:19 PM
Ramulator's Avatar
Ramulator
This is my rig , she is getting a suspension lift in the near future ..now has 3" body lift. I did the body work myself (first attempt) welded in cab corners,rockers,box panels...and i learned most of it on an autobody forum ! Similar to the way i'm learmning about engines right now on this forum.
Old Jan 7, 2010 | 04:02 PM
halfamil's Avatar
halfamil
How much HP/Torque do you want?
Old Jan 7, 2010 | 04:39 PM
Ramulator's Avatar
Ramulator
Well my 5.9 is tuff as hell but doesn't seem to turn my 33" tires strong enough...a few nights ago i was out playing in 1 foot of wet snow , the rims were full of snow and the undercarrage a bit...this bogged the old girl down termendously...she was straving for power ...anyway i would guess 100 hp over stock might do it for me ...which would be what ??
