Extremely confusing taillight/gauge lights/brake light problem..
Old Jan 8, 2010 | 10:55 PM
yakkier's Avatar
yakkier
Question Extremely confusing taillight/gauge lights/brake light problem..
Hello my peoples i am back, been 2 years since iv been gone and everything has changed ?!
anyways i have an 1994 dodge ram 5.2 single cab 4x4 that has an issue in which i need the help of my fellow dodge lovers, I have no tailights,brakelights, or guage lights. Now yes iv done all the normal things, changed bulbs fuses etc etc. My hazards work, my headlights work High and lowbeams, my cig lighter works and all warning lights work on the dash, Except for the lights iv already mentiond. it all started two days ago i lost my drivers side tailight, Np easy fix just change the blub. guess what i changed the bulb an it blew a fuse, and i lost my guage lights, and also passengerside tailight. so i changed the fuse and nothing has come back on.
It's 0 dagrees outside and 20 below with windchill and im in an unheated garage, wont some of my old friends PLEASE GIVE ME SOME SUGGESTIONS!
ty in advance.
Old Jan 9, 2010 | 12:05 AM
95MaroonMonster's Avatar
95MaroonMonster
check for shorted wires
Old Jan 9, 2010 | 04:03 AM
halfamil's Avatar
halfamil
IP/Horn/Parking Lamps are on the same circut(No.4) in the PDC under the hood.It's a 50 amp red. Always make sure everything is turned off when changing fuses or they will immediatey blow.
Old Jan 9, 2010 | 06:50 AM
95RAM360's Avatar
95RAM360
ground wire at the rear of chassis...i had almost an identical problem except i had alot more wrong than you, and 1 ground wre fixed it all. it was at the rear where it goes into the first mutil-port connector...the ground had broken right off from it. re-wired it and havent had a problem since
Old Jan 9, 2010 | 06:55 AM
jsw0767's Avatar
jsw0767
On my 97 the fuse for tail lights aodgauge lights started to always blow when I wouldtfirst turn on lights. Never lost brake lights. Turned out to be bad head light switch. Cjgeck it out.
Old Jan 9, 2010 | 07:04 AM
halfamil's Avatar
halfamil
Yes,that could be his problem.There has been 4 headlight switches installed in my truck.
Old Jan 9, 2010 | 09:25 AM
BigRedRam95's Avatar
BigRedRam95
Not to hijack the thread but I am having a problem with my reverse lights it will blow a fuse every 2-3 months any ideas how to fix them
Old Jan 9, 2010 | 09:16 PM
yakkier's Avatar
yakkier
Ty for the replies, im going to dive into the problem tomorrow and try and figure it out. i'll post the solution once i find it!
Old Jan 10, 2010 | 08:32 AM
dhvaughan's Avatar
dhvaughan
after i first bought my truck i noticed i was semi-regularly blowing the reverse light fuse, couldn't figure out why. later on i was messing with the trailer wiring and found that the previous owner had done some custom wiring and connected the reverse light lead to the 4 pin ground. duh. i guess he had something custom on the trailer end to make this work but it sure confused me. every time i towed something i blew a reverse light fuse.
if you have the towing package, one of the 6 pin, (maybe 5 pin) is the reverse light, so you might have a problem in the wiring of the truck, or you may be towing something with a wiring problem.
Old Jan 10, 2010 | 04:57 PM
yakkier's Avatar
yakkier
Unhappy
Found one problem, i found a wire that was broken, that fixed my tailights and my guage lights, but i cant figure out whats going on with my brake lights now, they were working the night i got home after all this started happening and i changed some fuses out an now my damn brake lights dont work, including the 3rd light on the cab.
it's too cold to be trying to trouble shoot all the wires because the truck is dripping wet with melted snow, and im rolling around on the cold garage floor on a creaper, hopfully i can drive it back n forth to work since atleast i have tailights and guage lights blinkers etc, just hope the **** burnsville cops dont pull me over.
