Anyone NOT have a blown plenum gasket?
Old Jan 11, 2010 | 02:30 PM
  #21
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
i have 156,000 on my 99 sport 1500 and have never changed the plentum gask, runs great...
Old Jan 11, 2010 | 02:50 PM
  #22
01Green5.9L's Avatar
01Green5.9L
144,000 did not change it yet,mine runs great to
Old Jan 11, 2010 | 03:11 PM
  #23
PurplDodge's Avatar
PurplDodge
Originally Posted by 70x7
maybe a stupid question but how would you know if it needed to be replaced?
You have a Magnum engine.
Old Jan 11, 2010 | 03:28 PM
  #24
cptcrash80's Avatar
cptcrash80
I replaced mine earlier this year, but I'm sure it had been blown for a while. Truck was 2xx,xxx miles when I got it. When I took off the intake there was oil draining out of it . But she's all better now.
Old Jan 11, 2010 | 03:52 PM
  #25
bigtman07's Avatar
bigtman07
108,xxx miles and gonna replace it this spring just as a precaution. 98 1500 5.9
Old Jan 11, 2010 | 04:23 PM
  #26
leahyhfarms's Avatar
leahyhfarms
99000 and its been blown for the last 4000- 5000 miles that I know, could be gone longer I don't know,the only thing it uses almost no oil.
Old Jan 11, 2010 | 09:55 PM
  #27
70x7's Avatar
70x7
ok, I guess I will continue with the stupid questions and ask what that means...
Old Jan 11, 2010 | 10:01 PM
  #28
95MaroonMonster's Avatar
95MaroonMonster
it means it's blown...it happens to basically all of them...even mine and im not that hard on the truck....
....oh wait, yea i am
Old Jan 11, 2010 | 10:37 PM
  #29
CSXfan's Avatar
CSXfan
If you have a 5.2 or 5.9 v8 engine in your 2nd generation or early 3rd generation ram it is likely that the plenum gasket is blown because it is a design flaw. If you notice poor performance, poor gas mileage, burning oil, pinging (spark nock) under acceleration, blue smoke coming out of the tailpipe on startup, or oil pooling in the intake manifold, there is a very good chance the plenum gasket is blown. The only way to tell for sure whether or not it's blown is to do a vacuum test.
leahyhfarms, if I were you I'd fix the leak before the oil you're burning takes out your catalytic converter and o2 sensors.
I bought my truck with 110xxx miles and a blown plenum. I wonder what causes some to fail and others not. Driving habits? Climate? Maintenance? Tire pressure?
Old Jan 11, 2010 | 11:09 PM
  #30
PurplDodge's Avatar
PurplDodge
What it means is because you have a 318 or 360 Magnum engine, your plenum gasket is blown, or it will be blown. I say that because it is inevitable. There is no need to check down your throttle body, or do a vaccum test, one day it will be blown sooner than later.
