What have you replaced since.....
Old Jan 11, 2010 | 12:57 AM
johnjokela's Avatar
johnjokela
Default What have you replaced since.....
not sure if this has been done yet(didnt search ..go figure)but curious what have you replaced since owning your rams... I'VE HAD TO REPLACE : both front axle u joints, both hub and bearing assembly,axle seals,<~~~(only the big nut was holding the tire on) trac bar,all ball joints,heater core ,timing chain ,oil pan gasket, water pump, t-stat,harmonic balancer,timing chain cover,steering stabilizer, and TPS sensor, + numerous fluid changes, tune ups and set of spendy tires,and brakes ,.... IN THE WORKS= broken manifold bolts,rear leafs replacements, shocks, full front brake service ,pads, rotors, calipers+brackets...all this $$ adds up fast.
Old Jan 11, 2010 | 01:01 AM
wake's Avatar
wake
due to the fact that its broken..and i only put 1500 miles on it since i bought it
ill add my two cents
upper and lower right side ball joints
pads
calipers
rotors
oil pump/pan/gasket
battery
EDIT: thanks to the below post
ive put new OEM turn bulbs all around on the outside..inside on the other hand is a different story
other owners have replaced
UIM/LIM gaskets
timing chain
alternator
spindle gear on front axle
front drive shaft u joints
and a few other things
Old Jan 11, 2010 | 01:06 AM
95MaroonMonster's Avatar
95MaroonMonster
um, balljoints, wheel bearings TREs on both the tie rod and drag link, axle seals, brake line, 2 head lights, 3rd brake light bulbs, turnsignal bulb, plenum gasket (hughes FTW), PCV vavle, bug shield (don't ask) and the gas that was in the tank when i bought it (it ran away...)
edit: also the left side stub shaft and u-joints on both side
Old Jan 11, 2010 | 01:12 AM
Maxx_Magnum's Avatar
Maxx_Magnum
I've owned mine since Dec. 31, 2008, here's my list:
both front wheel bearings
balljoints
1 front U-joint
steering stabilizer
Idler pulley and belt
PCV valve
pretty much it that I can think of.... Not bad for my first year with a Dodge truck, hopin for many more
Old Jan 11, 2010 | 02:52 AM
Weldor's Avatar
Weldor
Ive had to replace gas alot. But other then that just a battery.
Old Jan 11, 2010 | 03:03 AM
halfamil's Avatar
halfamil
Originally Posted by Weldor
Ive had to replace gas alot. .
LMAO,me too brother!!!
Old Jan 11, 2010 | 03:16 AM
Sheriff420's Avatar
Sheriff420
got it feb. 2004
replaced:
rebuilt transmission
plenum gasket
both u joints on the front axle
both axle seals on the front axle
u joints on the rear drive shaft
valve cover gaskets
spark plugs a few times trying to find some that i like
spark plug wires twice
distributor cap/rotor twice
headlight bulbs
headlights
a bunch of oil/transmission/transfer case fluid/filter changes
radiator
thermostat twice
bottom radiator hose
gear oil front and rear
driver mirror-cracked when i hit a bump in cold weather
a bunch of touch up paint-that 4x4 badge welcomes scratches from branches
muffler with glass packs then with a y pipe
horns
battery
transfer case input shaft seal
transmission output shaft seal
rotors
brake pads 3 times
brake shoes twice
wheel cylinders
all the springs and the adjuster in the back right drum
heater core
head unit
third brake light- sealed up the old one then got an led replacement shortly after
drop in bed liner with herculiner
tires twice
fog light relay with a little piece of wire
asd relay
IAC
TPS
PCV
RWSS
CPS
upstream o2 sensor
manifolds with headers
stock air box with free k&n CAI then with a mr. gasket 14x3 with a k&n filter
belt tensioner
belt
battery clamps
negative battery cable
license plate bracket - mud ripped the old one off
dash cover to hide the gaping hole
cruise control servo
check valves for the wild vents
tie rod boots
sway bar link bushings
shocks
a couple fuel injector locking tabs (the red things) with zip ties
the hood liner with nothing
a few clips on the bumper and plastic fender liners with nuts and bolts
Old Jan 11, 2010 | 08:01 AM
Flue's Avatar
Flue
Acquired Feb 2008...I think
Haven't replaced that much for having 167k.
Current:
Front wheel U-joints,
Steering linkage-everything but gear and pitman arm.
A/C clutch and pulley,
battery,
e-fan conversion
wires/plugs/cap/rotor
Soon to replace:
heater core (after I ensure blend door is working correctly) Headers and muffler. Headers look like @$$, and I think the muffler has a leak under the glove box,
rear solid window for sliding,
that ram tough steering bushing thing and the steering linkage. But I want to cry when I see the prices on the Jorgenson shaft,
drive shaft U-joints. front/back.
That's not too bad of a list. Maybe I'll have it all done by Oct.
Old Jan 11, 2010 | 08:24 AM
97black_ram's Avatar
97black_ram
A lot of gas, plenum, heads, water pump, alternator, battery, driver u-joint, driver hub, tires, many fluid changes, bulbs, flex fan, plugs, cap/rotor, wires, coil, check valve delete, heater core, oil pan gasket, glasspack, and other stuff i can't remember all within a year and a half.
Old Jan 11, 2010 | 09:30 AM
clipper77's Avatar
clipper77
Got it in Sep. '09 for $1,000....2 Upper Ball Joints
Front shocks
Rear shocks
Pitman Arm
Idler Arm
Clockspring
Brake Caliper
Brake Line
Brake Pads
Thermostat
Upper Coolant Hose
Lower Coolant Hose
Bypass Hose
Intake Manifold Gaskets (upper and lower)
Throttle Body Gasket
Air Housing Gasket
Valve Cover Gaskets
Starter (shop)
Tires (33/12.5/16.5 BFG M/T)
Horn (shop)
Oil (Penzoil Platinum Full Synth.)
Oil Filter
Idler Pulley
Coolant
Lug Nuts
