Door buzzer
Old Feb 10, 2010 | 04:43 PM
JackJ's Avatar
JackJ
Default Door buzzer
Can I disable it any way, it annoys the crap outta me, that I want to see what it is like to ride with the doors off this summer in a full size truck. I looked at the fuse box under the dash and there is no fuse in the spot that says buzzer.
Old Feb 10, 2010 | 04:46 PM
BIGRED97's Avatar
BIGRED97
either take it out, or just break it off, i broke mine a few years ago, only thing is it doesnt remind you if your lights are left on. but no big deal, i replaced it and remember now how annoying it is. there is the little black thing in the door jam just put your foot up on it and let your foot slip. problem solved.
Old Feb 10, 2010 | 05:23 PM
rumble_truck's Avatar
rumble_truck
there's a buzzer fuse, or the buzzer it's self. I removed mine.
Old Feb 10, 2010 | 05:37 PM
White Ram's Avatar
White Ram
I read somewhere once that you can replace it with a newer style that chimes rather than buzzes. The part number is 56007373.
I haven't tried it myself; wonder if anybody else has.
Old Feb 10, 2010 | 05:39 PM
JackJ's Avatar
JackJ
Where is the buzzer, I have tried to locate it by sound but I have not been able to.
Old Feb 10, 2010 | 08:14 PM
redheadhunter21's Avatar
redheadhunter21
If you look at the fuse panel on the side of the dash its towards the front of the truck on the side of the fuse panel its a black box you can feel it buzzing.
Old Feb 10, 2010 | 09:34 PM
Ram_Me's Avatar
Ram_Me
You could just tape down the switch..
Old Feb 10, 2010 | 09:47 PM
dhvaughan's Avatar
dhvaughan
are you talking about the buzz/chime that's created by the door open/key in ignition condition.
if so, there's an easy fix. there is an electrical connector on the ignition switch. remove the covers from the steering column to expose the base of the ignition switch and unplug the connector. problem solved and you retain you other warnings regarding headlights on, low fuel, etc.
^ ram has a good point. if you're going to ride with the doors off, then your dome light is going to come on. you might want to just tape the door switch down or disconnect that wire.
Old Feb 10, 2010 | 09:49 PM
Ram_Me's Avatar
Ram_Me
^ Do you think that'll work for '96s like his?
Old Feb 10, 2010 | 10:07 PM
dhvaughan's Avatar
dhvaughan
i think so. the "key in switch" indicator is likely the same.
