Bad fan clutch?
Old Feb 25, 2010 | 01:04 PM
Sheriff420's Avatar
Sheriff420
Default Bad fan clutch?
Is it normal to have the wobble with a little forward/reverse pushing? It isn't much at all and the clutch has decent tension.
I popped my belt off to see if I could find my noisy bearing and I noticed the slight wobble in the fan with a little pushing.
http://www.youtube.com/watch?v=KTUsR41EEMY
Old Feb 25, 2010 | 01:21 PM
halfamil's Avatar
halfamil
I wouldn't think that is normal. I'm going to check mine.
Old Feb 25, 2010 | 01:58 PM
wjxavier's Avatar
wjxavier
i wouldn't think thats normal either, i'm going to check mine as well when i go to work.
Old Feb 25, 2010 | 02:00 PM
Gerehead8's Avatar
Gerehead8
I think mine is actually like that but I have never worried about it.
Old Feb 25, 2010 | 02:42 PM
USAF90's Avatar
USAF90
only one way to find out. rap a nice thick towel around your hand/arm.. then try to stop the fan when the motor is running... seriously
if you CAN stop the fan, then its bad..
EDIT: remember theres gonna be tension on the fan clutch (hard to spin). the only purpose for it is to "slip" when the engine is spinning. otherwise, if it didnt slip, you would have a super loud roaring under the hood. and if it didnt spin at all, obviously you wouldnt cool the engine down enough.
Old Feb 25, 2010 | 02:47 PM
blbikerood's Avatar
blbikerood
Default I just had mine replaced about an hour ago....
I work at a school and the bus mechanic swapped it out for me for 20bucks. He said it had "play" in it and it was as close to being locked up as any he had seen. That would explain why I could barely turn the fan by hand, so even if it isn't a major issue now with the "play" in it, it might cause it to be a problem like I had.
Old Feb 25, 2010 | 02:49 PM
Sheriff420's Avatar
Sheriff420
I don't understand the procedure, would you care to come demonstrate it for me?
If It didn't spin at all then I would think that it would over-cool the engine.
Old Feb 25, 2010 | 02:58 PM
blbikerood's Avatar
blbikerood
Default You are correct sheriff
It did overcool the engine and my heat sucked. I bet it wasn't getting much over 130.
***edit** It also was SUPER LOUD! I sounded like an airplane trying to take off!
Old Feb 25, 2010 | 03:01 PM
USAF90's Avatar
USAF90
if the FAN didnt spin at all, then you wouldnt get any air flow in the engine bay (hence over-heating the engine)
Old Feb 25, 2010 | 03:02 PM
BlueBeast2's Avatar
BlueBeast2
Time for E fans lol
