How to get the o2 sensor out?
Old Mar 2, 2010 | 09:19 PM
sk8erdude's Avatar
sk8erdude
Default How to get the o2 sensor out?
alright so now im having problems getting the o2 sensor out. i soaked it in dw-30 and tried to get it off with a wrench, but it only started to round it off. how the heck do you get this thing off?
Old Mar 2, 2010 | 09:23 PM
pcfixerpro's Avatar
pcfixerpro
its a 20 something mm wrench (22mm?), but... normally they have o2 sensor sockets which you slid on and twist out. I rented one at autozone and had to throw a cheater pipe on the end of the tool to get my originals to break free. Now I can just get them out with a regular wrench.
Old Mar 2, 2010 | 09:26 PM
yakkier's Avatar
yakkier
Wd-40!!!!!!!
Old Mar 2, 2010 | 09:32 PM
sk8erdude's Avatar
sk8erdude
well thanks, i didnt no that they made a specific socket for it. and sorry about the dw-30. i have a buddy who isnt much into cars or anything mechanical and he called it that once, i guess he didnt no what exactly it was called, so now i say that all the time
Old Mar 2, 2010 | 09:37 PM
yakkier's Avatar
yakkier
lmao smartass
Old Mar 2, 2010 | 10:07 PM
sit22 II's Avatar
sit22 II
If you cant get the tool or you round it off too much you can cut the top of the sensor and put a deep socket on it
Old Mar 2, 2010 | 10:10 PM
rideordie's Avatar
rideordie
Like others have said, either get a socket for it (I think it is 21mm IIRC), or use a line wrench. Soak it daily in wd40 or PB blaster and a few days later it should come right off with one of the two.
Old Mar 2, 2010 | 10:28 PM
dhvaughan's Avatar
dhvaughan
a good pair of tight clamping vise grips can probably show it who's boss.
also, soak it down with penetrating oil and let it soak as long as possible. pb-blaster, knocker, etc. you can also try heating the pipe area. be careful not to melt your wires.
Old Mar 2, 2010 | 10:58 PM
yakkier's Avatar
yakkier
or let it run for about 20 minutes and bring it up to running temp then try an break it loose
Old Mar 2, 2010 | 11:06 PM
sk8erdude's Avatar
sk8erdude
ive let in warm up and ive soaked it several times. i cant get it off without rounding it with a wrench so im gonna have to get a special socket
