Old Aug 5, 2015, 12:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
4x4 actuator ?
Old Mar 11, 2010 | 08:47 PM
hammerhead1985's Avatar
hammerhead1985
I think I saw the replacement cable on Summit Racing the other day when I was looking at the kit...
Old Jan 23, 2012 | 03:38 AM
Gary B Clatt's Avatar
Gary B Clatt
i also have grief with my 4x4 actuator. 1997 2500. Where do I shop for the posi kit?
Old Jan 23, 2012 | 04:30 AM
Josh_Putman's Avatar
Josh_Putman
I think whoever invented a vacuum operated four wheel drive system should be horsewhipped. It makes absolutely no sense to me whatsoever. What the hell is wrong with mechanical linkages that work when you need them to? That and manual hubs.
Makes me appreciate my old 1969 Chevy truck that much more.
Old Jan 23, 2012 | 04:59 PM
zman17's Avatar
zman17
Retired Moderator - RIP
convenience my friend, we Americans are ALL about convenience and making life as easy as possible. Which is why 90% of us(me included) are over weight fat azz's. LOL
Old Jan 23, 2012 | 05:27 PM
99dodge318's Avatar
99dodge318
You can find the kits online at summitracing.com, amazon.com, even ebay.... Just make sure you get the kit for your truck, also they make two different version.
Old May 31, 2013 | 07:23 PM
mikepatrickmiller's Avatar
mikepatrickmiller
Default 1989 dodge ram charger
which side does the fork on the 4wd actuator go too , the actual actuator is on the drivers side . too lock it manually lock it in 4wd .
Old Jun 1, 2013 | 10:49 AM
The vacuum actuator should be on the passenger side of the housing..... if it isn't, I can see how that might cause some trouble....
Old Jun 2, 2013 | 06:22 PM
mikepatrickmiller
how can that be a problem , its a 89 1/2 ton ram charger . do you think that maybe the front end could be a 3/4 ton front axle maybe. im very stumped
Old Jun 2, 2013 | 06:32 PM
merc225hp's Avatar
merc225hp
Welcome to DF
You are right it is on the drivers side for a 89, so you would need to move to fork/collar towards the drivers wheel to lock it in 4wd.
You have posted in the 2nd gen area not the 1st gen area (you have a first gen truck), our trucks have the cad on the pass side of the diff.
Please take the time to fill out your sig with your trucks info, that will help others when answering your Q's.
Old Jun 2, 2013 | 07:13 PM
That is rather a key piece of information..... and why we ask that you put such info in your sig, and profile. Merc is quite correct.
