machining 50mm throttle body
Old Mar 18, 2010 | 09:33 PM
omegax's Avatar
omegax
Default machining 50mm throttle body
Hey, since i have access to the machine shops at my school (almost all HAAS CNC tooling, mini mills, small lathes, 30HP lathe, 5-axis, and large milling centers) I figured I would make some parts for my truck, starting with boring the throttle body to 50mm for a 318 engine. I have seen the poor mans TB guide and it seems simple enough and i believe i will get a much more accurate surface finish with the CNC mills, plus I thoroughly enjoy using them. I just found out there is a pick and pull junkyard in the area with 15 acres of vehicles, i'm hoping i can pull an extra throttle body off a vehicle there (same size engine). Any tips on machining for a fine surface finish (I have machined a bunch of parts there but never honed anything), or tips on going to a junkyard?
I have a 96 dodge ram 1500 5.2L with 103,000 miles.
Old Mar 18, 2010 | 09:38 PM
dodgeram07's Avatar
dodgeram07
96-01 5.2 or 5.9...................94-95 have diff hook up for the TV
Old Mar 18, 2010 | 09:44 PM
yakkier's Avatar
yakkier
usually throttle bodies are only around 12 to 15 bucks at junkyards, i'd consider buying a couple just incase you **** up the first one. Also make sure the butterfly's are even when you put them back in, when i did my fastman mod it took me a couple days and alot of curing to get it back to where it needed to be, your AIC will compensate for some minor gaping in the botterfly's but it will cause your idle to be on stable and will become a pain in the *** to start if it's too uneven.
Old Mar 18, 2010 | 11:09 PM
lastrights's Avatar
lastrights
you could at least just shave off the flys on the top
Old Mar 19, 2010 | 02:08 AM
J415's Avatar
J415
Originally Posted by yakkier
usually throttle bodies are only around 12 to 15 bucks at junkyards...
I wish that where true in the bay area. There $40 in my neck of the woods.
Old Mar 19, 2010 | 02:14 AM
yakkier's Avatar
yakkier
Yea thats a freakin rip off, the yards here even give you the sensor's for free
Old Mar 20, 2010 | 12:32 AM
omegax's Avatar
omegax
Default great advice
Thanks for the advice, i should get to the junkyard and get it machined within the next few weeks, i'll post pics when i'm done. Is it possible to cut or find new butterfly valves? If the only ones i find are warped?
Old Mar 20, 2010 | 01:46 AM
yakkier's Avatar
yakkier
Summitracing.com has replacements
