York 210 OBA Install
Old 05-02-2010, 03:52 PM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
I'd buy a set of brackets for sure.
Old 05-02-2010, 04:14 PM
Maxx_Magnum's Avatar
Maxx_Magnum
Maxx_Magnum is offline
So Cartman, will that run an impact gun? long enough to zip off a wheel for example?
Old 05-02-2010, 04:43 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,307 Likes on 3,052 Posts
According to what I have read, yes, it will. Should be golden for one tire, wait a bit, and move on to the next, even with the truck idling.
Old 05-02-2010, 04:55 PM
Maxx_Magnum
ya I see that now at the bottom of one of his posts about running any air tool he'd need... thanks for pointin it out
Old 05-02-2010, 05:29 PM
EricCartman's Avatar
EricCartman
EricCartman is offline
Yeah, it will run an impact gun no problem. You are supposed to be able to do that without a storage tank,. I have a 3 gallon tank... so there really aren't any problems (even at idle).
I've used it to air up tires, cut rusted hinges off farm gates with what is basically a die grinder with a cutoff wheel, charge spud guns, honk train horns (one of the funner uses), fill up inflatable tow toys for boating... just about anywhere compressed air would be useful. I'll even hook up a hose with a blow gun attachment to clean off my dash when I wash the truck.
My next OBA toy/use will be for load helper springs in the back to help with towing.
Cartman
Old 05-03-2010, 09:58 AM
beamwalker's Avatar
beamwalker
beamwalker is offline
nice craftsmanship!
Old 05-03-2010, 11:37 AM
EricCartman
Thanks for all the kind comments. I've added two more pictures to my original post... horns and air tank.
Old 05-03-2010, 11:51 AM
Would you consider doing some more of the brackets, and selling them? If so, how much would you like to get for them? (plus shipping, of course.)
Old 05-03-2010, 12:52 PM
99dodge318's Avatar
99dodge318
99dodge318 is offline
id be down for a set, people at the job site wouldnt know what to think. could you use a bigger tank maybe 10-20 gallon or would that kill the pump?
Old 05-03-2010, 01:00 PM
Larger tank would take longer to fill... but, would allow for continuous operation of more demanding air tools. I would be more concerned with where you would mount a tank that large.... Doesn't really need anything bigger.... unless you are doing rebuilds on the side of the road.
Quick Reply: York 210 OBA Install
