MonteC's Transmission Corner (For Info Only)
Old Jul 20, 2010 | 08:34 PM
  #541
MonteC's Avatar
MonteC
Originally Posted by Nando Vazquez
Just one more question MonteC. We pressure tested it today and found out that the govenor was not getting any pressure at 1k 1.5k and 2k RPMs. I just need to know what controls the govenor pressure inside the valve body, or anywhere else. Thanks in advance. The transmission is a 2WD 46re.
Well you dont have a governor in the transmission. You have a governor pressure solenoid, and a sensor. It reads from the tps and increases and decreases depending on the throttle.
Old Jul 20, 2010 | 08:38 PM
  #542
MonteC's Avatar
MonteC
Originally Posted by offroadgearhead
Hi, I bought a 95 1500 5.9L 4x4 about a week ago knowing it needed a transmission. I have done some searching on this site finding what other transmissions would work on it, But does it make a difference if the truck is 2wd or 4wd. To the best of my knowledge the transfer case is still good and it seems to be a lot easier to find 2wd transmissions than 4wd. So, will it work and if so, what issues will I encounter. Thanks.
2wd and 4wd have different o/d housings. You can swap them out, but its a good bit of work.
Old Jul 20, 2010 | 08:39 PM
  #543
MonteC's Avatar
MonteC
Originally Posted by lord0fsal3m
any ideas on this? or is this out of your area of expertise?
Ideas on adjusting the tps? I dont mess with them everyday. Do a search on the forum or crack open your FSM.
Old Jul 20, 2010 | 08:44 PM
  #544
MonteC's Avatar
MonteC
Originally Posted by jKsled
I understand what you're saying, however, I am sure on the mechanical end.
The limp mode problem I am not sure.
Like I said, new solenoids, but it will start in third, only go into 1st and 2nd manually, and not into o/d.
If you could just give me a way to start testing these, or the computer, like you mentioned earlier, that would really help.
The only mechanical issue I have a problem with is this leak from the front. It seems to me that the TC is pulled out too far when I bolt the flex plate onto it. Is it possible to use spacers or something between them?
Have you put a scan tool on the truck to see what the computer is doing and reading?
No you cannot just put spacers. Something is not right, you need to find out what you did wrong.
Old Jul 20, 2010 | 10:36 PM
  #545
jKsled's Avatar
jKsled
scan tool indicates "transmission fluid pressure control solenoid" I am assuming this is the governer pressure solenoid. this is a new part.
It also indicates the speed sensor. not sure if that would make it go into limp mode but i'm fixing that problem as we speak.
As far as the TC issue, I think I have figured out the problem. the old TC siezed up the bushing on it, so it pulled out with the old TC and I missed putting in the new one.
However, when the old one siezed up around the TC shaft, it started to wear a groove on the pump unit. Not a big one, so I'm not sure if i can get away with using it, or if I should try and find a replacement. Basically right where that bushing goes is widened a slight bit, so the new bushing is loose and not a tight fit....
Old Jul 21, 2010 | 12:53 AM
  #546
Nando Vazquez's Avatar
Nando Vazquez
Thanks for the info. Does this mean I have to replace the solenoid & the sensor or the TPS sensor. Could this be what is keeping my transmission from shifting into 2nd and 3rd.
What would you recommend I do next.
Also when I shift manually it will grab 2nd for a couple of seconds then release again.
Thanks in advance.
Old Jul 21, 2010 | 02:01 PM
  #547
TSuppa's Avatar
TSuppa
Default valve body screws
Hi Monte,
I posted this elsewhere on forum but havent got an answer yet. I am attempting to reassembly the valve body. There are 13 screws which hold the body parts together, 12 of them are 2" long, one is 2.5". I am trying to determine where the longer screw goes.
Thanks
Old Jul 21, 2010 | 09:16 PM
  #548
MonteC's Avatar
MonteC
Originally Posted by TSuppa
Hi Monte,
Thanks
look at the 2 bolts that hold the filter on. The old style used 3 bolts, when they changed to 2 bolts they left the third bolt long.
Old Jul 21, 2010 | 09:17 PM
  #549
MonteC's Avatar
MonteC
So you forgot to put a pump bushing in and you want me to believe everything you did is correct? Who's to say you didnt forget something else? You need to get scan tool not a code reader.
Old Jul 21, 2010 | 09:18 PM
  #550
MonteC's Avatar
MonteC
Thanks in advance.
It should manual shift fine. If it looses 2nd gear then you have a problem with the band or the adjustment.
