MonteC's Transmission Corner (For Info Only)
Old Aug 10, 2010 | 12:05 AM
  #641
TitanOneSeven's Avatar
TitanOneSeven
Had a question here but found my answer, ignore this post since I can't seem to delete this post.
Old Aug 10, 2010 | 02:54 AM
  #642
Slomojo's Avatar
Slomojo
Here is a good one...
First of all, what kind of automatic transmission is behind a 8.0L V10, 47 or 48 RH/RE transmission???
Second of all, is the bolt pattern on the V10 the same as a V8?
If so, could it be a bright idea to get an Automatic out of a V10 to put it behind a V8 for tougher internals and more torque holding capacity without sacrificing anything or could there be something I am missing?
Was at the Junkyard today just wondering about the possibilities and now that this thread is here, I just thought I'd ask...
Thanks in advance Monte
Old Aug 10, 2010 | 07:54 PM
  #643
Joshfinn's Avatar
Joshfinn
The dreaded tranns code... I have a 2000 dodge ram 1500, 5.9 gas, 46re. The problem im having is a recurring tranns code p1740. I bought the truck will 100k mi on it not sure if the transmission valve body pressure boost valve cover plate has been replaced (i read in a tsb something about some orifice not being large enough on the plate) 1 month after buying the truck the code popped up, luckily at the time i had a 1k mi warranty. I would have to let off the pedal and wait a second or to for it to shift. Took it to the dealer, they swapped out the 2 solenoids/filter/fluid.... Code = gone/no more symptoms.... 1 month later the code came back. The truck shifts fine, and has no symptoms at all. I've cleared to code multiple times, and the code come back with a vengeance after 30 miles..
Any ideas what could be causing this problem?
-Josh-
Old Aug 10, 2010 | 11:17 PM
  #644
isenegger's Avatar
isenegger
i got a question.... on my 01 ram if i floor it from say 60 and make it downshift to 3rd (could be second, not sure) to pass someone on the highway... as it speeds up and the rpms hit about 4000 it seems to fall out of gear like to neutral or maybe its a slip. the tranny guy in town doesnt know why it would do that. has anyone else had this problem? if i drive it normal and dont dog it, it will not do that. any cure? thanks!
Old Aug 11, 2010 | 02:33 PM
  #645
J415's Avatar
J415
did you mean upshift? If so, the GM solenoid should be your cure.
Old Aug 11, 2010 | 10:30 PM
  #646
isenegger's Avatar
isenegger
no i mean when im doing 60 or 70 down the highway and i floor it to pass it DOWNSHIFTS a gear or two and while its in that gear as soon as the rpms reach about 4000 or so its like it goes to neutral or something. so i always just let off and it goes back into gear. anyone else had theirs do that?
Old Aug 12, 2010 | 06:15 AM
  #647
m2hbvic's Avatar
m2hbvic
Hi Robert,
Sent you another PM with a question on heavy-duty parts for a 46RH.
THANKS,
Vic
Old Aug 12, 2010 | 11:25 AM
  #648
There is a list on page six of this thread. Just part numbers from WITTrans though. The list was a 'suggested list' of parts for a truck that regularly towed a 7000 pound trailer.
Old Aug 12, 2010 | 01:46 PM
  #649
J415's Avatar
J415
Originally Posted by m2hbvic
Hi Robert,
THANKS,
Vic
Also, it's a good thing to post your question here and not PM because someone WILL ask the same question your asking. So for the sake of Monte not answering the same question twice, post your questions here.
Old Aug 12, 2010 | 08:48 PM
  #650
MonteC's Avatar
MonteC
Sorry bud. Like the many others before you who have thought of it. It just dont work.
