Stock cam timing specs.
I'm trying to use an online calculator that is asking for exhaust lobe timing. Anyone know this?
Tried searching. The word "cam" was removed from my search. Please Dodge forum administration gods hear my pleas for a search engine overhaul. This site is almost perfect. I'm thinking words like "cam" should not be discarded in searches here.
5.9L ENGINE
Engine Specifications DESCRIPTION SPECIFICATION
GENERAL SPECIFICATIONS
Engine Type 90° V-8 OHV
Bore and Stroke 101.6 x 90.9 mm
(4.00 x 3.58 in.)
Displacement 5.9L (360 c.i.)
Compression Ratio 9.1:1
Firing Order 1–8–4–3–6–5–7–2
Lubrication Pressure Feed – Full Flow
Filtration
Cooling System Liquid Cooled – Forced
Circulation
Cylinder Block Cast Iron
Cylinder Head Cast Iron
Crankshaft Nodular Iron
Camshaft Nodular Cast Iron
Pistons Aluminum Alloy w/strut
Connecting Rods Forged Steel
Compression Pressure 689.5 kPa (100 psi) (Min.)
CAMSHAFT
Bearing Diameter
No. 1 50.800 – 50.825 mm
(2.000 – 2.001 in.)
No. 2 50.394 – 50.419 mm
(1.984 – 1.985 in.)
No. 3 50.013 – 50.038 mm
(1.969 – 1.970 in.)
No. 4 49.606 – 49.632 mm
(1.953 – 1.954 in.)
No. 5 39.688 – 39.713 mm
(1.5625 – 1.5635 in.)
Bearing Journal Diameter
No. 1 50.723 – 50.775 mm
(1.997 – 1.999 in.)
No. 2 50.317 – 50.368 mm
(1.981 – 1.983 in.)
No. 3 49.936 – 49.987 mm
(1.966 – 1.968 in.)
No. 4 49.53 – 49.581 mm
(1.950 – 1.952 in.)
No. 5 39.611 – 39.662 mm
(1.5595 – 1.5615 in.)
Bearing to Journal Clearance
Standard 0.0254 – 0.0762 mm
(0.001 – 0.003 in.)
Service Limit 0.127 mm (0.005 in.)
Camshaft End Play 0.051 – 0.254 mm
(0.002 – 0.010 in.)
CONNECTING RODS
Piston Pin bore Diameter 24.966 – 24.978 mm
(0.9829 – 0.9834 in.)
Side Clearance 0.152 – 0.356 mm
(0.006 – 0.014 in.)
CRANKSHAFT
Rod Journal
Diameter 53.950 – 53.975 mm
(2.124 – 2.125 in.)
Out of Round (Max.) 0.0254 mm (0.001 in.)
Taper (Max.) 0.0254 mm (0.001 in.)
Bearing Clearance 0.013 – 0.056 mm
(0.0005 – 0.0022 in.)
Main Bearing Journal
Diameter 71.361 – 71.387 mm
(2.8095 – 2.8105 in.)
Out of Round (Max.) 0.127 mm (0.001 in.)
Bearing Clearance
Journal #1 0.013 – 0.038 mm
(0.0005 – 0.0015 in.)
Journals # 2 - 5 0.013 – 0.051 mm
(0.0005 – 0.002 in.)
Service Limit
Journal #1 0.0381 mm (0.0015 in.)
Journals #2-5 0.064 mm (0.0025 in.)
Crankshaft End Play 0.051 – 0.178 mm
(0.002 – 0.007 in.)
Service Limit 0.254 mm (0.010 in.)
CYLINDER BLOCK
Cylinder Bore
Diameter 101.60 – 101.65 mm
(4.000 – 4.002 in.)
Lifter Bore
Diameter 22.99 – 23.01 mm
(0.9051 – 0.9059 in.)
Distributor Drive Bushing
Press Fit
Bushing to Bore Interference 0.0127 – 0.3556 mm
(0.0005 – 0.0140 in.)
Shaft to Bushing Clearance 0.0178 – 0.0686 mm
(0.0007 – 0.0027 in.)
CYLINDER HEAD AND VALVES
Valve Seat
Angle 44.25° – 44.75°
Runout (Max.) 0.0762 mm (0.003 in.)
Width (Finish)
Intake 1.016 – 1.524 mm
(0.040 – 0.060 in.)
Exhaust 1.524 – 2.032 mm
(0.060 – 0.080 in.)
Valves
Face Angle 43.25° – 43.75°
Head Diameter
Intake 47.752 mm (1.88 in.)
Exhaust 41.072 (1.617 in.)
Length (Overall)
Intake 126.21 – 126.85 mm
(4.969 – 4.994 in.)
Exhaust 126.44 – 127.30 mm
(4.978 – 5.012 in.)
Lift (@ zero lash)
Intake 10.414 mm (0.410 in.)
Exhaust 10.592 mm (0.417 in.)
Stem Diameter
Intake 9.449 - 9.474 mm
(0.372 - 0.373 in.)
Exhaust 9.423 - 9.449 mm
(0.371 - 0.372 in.)
Guide Bore 9.500 - 9.525 mm
(0.374 - 0.375 on.)
Stem to Guide Clearance
Intake 0.0254 - 0.0762 mm
(0.001 - 0.003 in.)
Exhaust 0.0508 - 0.1016 mm
(0.002 - 0.004 in.)
Service Limit 0.4318 - (0.017 in.)
Valve Springs
Free Length 49.962 mm (1.967 in.)
Spring Tension
Valve closed 378 N @ 41.66 mm
(85 lbs. @ 1.64 in.)
Valve open 890 N @ 30.89 mm
(200 lbs. @ 1.212 in.)
Number of Coils 6.8
Installed Height 41.66 mm (1.64 in.)
Wire Diameter 4.50 mm (0.177 in.)
HYDRAULIC TAPPETS
Body Diameter 22.949 - 22.962 mm
(0.9035 - 0.9040 in.)
Clearance (to bore) 0.0279 - 0.0610 mm
(0.0011 - 0.0024 in.)
Dry Lash 1.524 - 5.334 mm
(0.060 - 0.210 in.)
Push Rod Length 175.64 - 176.15 mm
(6.915 - 6.935 in.)
OIL PRESSURE
Curb Idle (Min.*) 41.4 kPa (6 psi)
@ 3000 rpm 207 - 552 kPa (30 - 80 psi)
Oil Pressure Bypass
Valve Setting 62 - 103 kPa (9 - 15 psi)
Switch Actuating Pressure 34.5 - 48.3 kPa (5 - 7 psi)
* If oil pressure is zero at curb idle, DO NOT RUN ENGINE.
OIL PUMP
Clearance over Rotors (Max.) 0.1016 mm (0.004 in.)
Cover Out of Flat (Max.) 0.0381 mm (0.0015 in.)
Inner Rotor Thickness (Min.) 20.955 mm (0.825 in.)
Outer Rotor
Clearance (Max.) 0.3556 mm (0.014 in.)
Diameter (Min.) 62.7126 mm (2.469 in.)
Tip Clearance between
Rotors (Max.) 0.2032 mm (0.008 in.)
PISTONS
Clearance at Top of Skirt 0.013 - 0.038 mm
(0.0005 - 0.0015 in.)
Land Clearance (Diam.) 0.508 - 0.660 mm
(0.020 - 0.026 in.)
Piston Length 81.03 mm (3.19 in.)
Piston Ring Groove Depth
Groove #1 and 2 4.761 - 4.912 mm
(0.187 - 0.193 in.)
Groove #3 3.996 - 4.177 mm
(0.157 - 0.164 in.)
Weight 582 - 586 grams
(20.53 - 20.67 oz.)
PISTON PINS
Clearance in Piston 0.006 - 0.019 mm
(0.00023 - 0.00074 in.)
Diameter 25.007 - 25.015 mm
(0.9845 - 0.9848 in.)
End Play NONE
Length 67.8 - 68.3 mm
(2.67 - 2.69 in.)
PISTON RINGS
Ring Gap
Compression Ring (Top) 0.30 - 0.55 mm
(0.012 - 0.022 in.)
Compression Ring (2nd) 0.55 - 0.80 mm
(0.022 - 0.031 in.)
Oil Control (Steel Rails) 0.381 - 1.397 mm
(0.015 - 0.055 in.)
Ring Side Clearance
Compression Rings 0.040 - 0.085 mm
(0.0016 - 0.0033 in.)
Oil Ring (Steel Rails) 0.05 - 0.21 mm
MAX (0.002 - 0.008 in.)
Ring Width
Compression rings 1.530 - 1.555 mm
(0.060 - 0.061 in.)
Oil Ring (Steel Rails) Max. 0.447 - 0.473 mm
(0.018 - 0.019 in.)
VALVE TIMING
Exhaust Valve
Closes (ATDC) 33°
Opens (BBDC) 56°
Duration 269°
Intake Valve
Closes (ATDC) 62°
Opens (BBDC) 7°
Duration 249°
Valve Overlap 41°
OVERSIZE AND UNDERSIZE ENGINE COMPONENT MARKINGS CHART OS-US Item Identification Location of
Identification
U/S Crankshaft R or M M-2-3 ect. Milled flat on
.025 MM (indicating No. 2 and No. three
(.001 in.) 3 main bearing crankshaft
journal) and/or counterweight.
R-1-4 ect.
(indicating No. 1 and
4 connecting rod
journal)
O/S Cylinder A Following
.508 mm Bores engine serial
(.020 in.) number.
O/S Tappets ♦ 3/8"
.203 mm diamond
(.008 in.) -shaped
stamp Top pad
— Front of
engine and flat
ground on
outside surface
of each O/S
tappet bore.
O/S Valve Stems X Milled pad
.127 mm adjacent to two
(.005 in.) 3/8" tapped
holes on each
end of cylinder
head.
I don't know if this is what you were looking for?
(4.00 x 3.58 in.)
Filtration
Circulation
CAMSHAFT
Bearing Diameter
(2.000 – 2.001 in.)
(1.984 – 1.985 in.)
(1.969 – 1.970 in.)
(1.953 – 1.954 in.)
(1.997 – 1.999 in.)
(1.981 – 1.983 in.)
(1.966 – 1.968 in.)
(1.950 – 1.952 in.)
(0.001 – 0.003 in.)
(0.002 – 0.010 in.)
CONNECTING RODS
(0.006 – 0.014 in.)
CRANKSHAFT
Rod Journal
(2.124 – 2.125 in.)
Bearing Clearance
Service Limit
(0.002 – 0.007 in.)
CYLINDER BLOCK
Cylinder Bore
(4.000 – 4.002 in.)
Lifter Bore
Press Fit
Valve Seat
Width (Finish)
(0.040 – 0.060 in.)
(0.060 – 0.080 in.)
Valves
Head Diameter
Length (Overall)
(4.969 – 4.994 in.)
(4.978 – 5.012 in.)
Lift (@ zero lash)
Stem Diameter
(0.372 - 0.373 in.)
(0.371 - 0.372 in.)
(0.374 - 0.375 on.)
(0.001 - 0.003 in.)
(0.002 - 0.004 in.)
Valve Springs
Spring Tension
Number of Coils 6.8
HYDRAULIC TAPPETS
(0.060 - 0.210 in.)
(6.915 - 6.935 in.)
OIL PRESSURE
Oil Pressure Bypass
OIL PUMP
Outer Rotor
PISTONS
(0.020 - 0.026 in.)
(0.187 - 0.193 in.)
(0.157 - 0.164 in.)
(20.53 - 20.67 oz.)
PISTON PINS
End Play NONE
(2.67 - 2.69 in.)
PISTON RINGS
Ring Gap
(0.012 - 0.022 in.)
(0.022 - 0.031 in.)
(0.015 - 0.055 in.)
Ring Side Clearance
Ring Width
(0.060 - 0.061 in.)
(0.018 - 0.019 in.)
VALVE TIMING
Exhaust Valve
Closes (ATDC) 33°
Opens (BBDC) 56°
Duration 269°
Intake Valve
Closes (ATDC) 62°
Opens (BBDC) 7°
Duration 249°
Valve Overlap 41°
Identification
R-1-4 ect.
4 connecting rod
journal)
(.020 in.) number.
O/S Tappets ♦ 3/8"
.203 mm diamond
(.008 in.) -shaped
stamp Top pad
— Front of
engine and flat
ground on
outside surface
of each O/S
tappet bore.
holes on each
end of cylinder
head.
Trending Topics
LOL! Awesome master tech! I needed it for my 1995 even though I forgot to mention that. The older 2nd gens have slightly differnt cam and thus cam timing than the newer ones apparently. I was originally trying to find the exhaust lobe center in order play around with this calculator. With aim4squirrelss link I was able to calculate that it will be at 109 degrees BTDC on my year. That link has the cam timing data for the old 2nd gens and the new ones too.
Thanks again everybody!
