Long crank times...
Old Apr 14, 2010 | 02:23 PM
MedicNathan's Avatar
MedicNathan
Default Long crank times...
Hello Everyone, I'm the FNG... Nice to meet you all.
I did some searching for similar problems on the site but didn't find anything very helpful. When i try to start my dodge, I need to crank on it for 5 secs for it to start. This happens weather it is hot or cold. However when i shut it off i have a few minutes when it will start right away. Also if i crank it for a second and release then it will start fine if i crank it a second time. Is the a fuel pump issue? I thought it might be IAC so i cleaned the soot off the valve. The throttle body is still covered though. I'm also just about certain i have a blown Plenum, but I didn't see anything about this being associated with the plenum. What do you all think?
Old Apr 14, 2010 | 06:57 PM
mike R's Avatar
mike R
My truck does the same thing! Maybe someone will have some ideas soon.
Old Apr 14, 2010 | 07:04 PM
Me&MyMopar's Avatar
Me&MyMopar
Sounds like the common problem with these fuel pumps. There's a valve on the pump that prevents fuel pressure from bleeding off when the truck isn't running. That valve goes bad, and allows the fuel pressure to bleed off. To be sure it's the pump, go out and cycle the fuel pump a few times by turning the key back and forth between ACC and off before cranking the motor. If it fires right away when you crank the motor over, than you need a new pump.
Old Apr 14, 2010 | 07:38 PM
dhvaughan's Avatar
dhvaughan
it could also be dirty oily plugs.
or stopped up IAC (clean the well and port into the throttle body, don't let the little red straw fall into the plenum)
you can check fuel pressure with a gauge at the rail, should be 49 psi
Old Apr 14, 2010 | 08:28 PM
mike R's Avatar
mike R
Thanks for the info everyone.
Old Apr 14, 2010 | 08:47 PM
mike R's Avatar
mike R
I think I may need a new fuel pump! I have a 1998 1500 is the pump in the tank???
Old Apr 14, 2010 | 09:16 PM
dhvaughan's Avatar
dhvaughan
yep. drop the tank or lift the bed. both are heavy.
Old Apr 14, 2010 | 09:20 PM
audiomechanic's Avatar
audiomechanic
Or, if your truck is like mine, just drive around for about 20 minutes and you'll be on E anyway so the tank will be much lighter. o_o
Old Apr 15, 2010 | 03:07 AM
lblair04's Avatar
lblair04
Mine did this. Did a fuel pressure test and pressure didnt hold after I shut it off. Replaced the fuel pump and all is well!
Old Apr 15, 2010 | 10:56 AM
fiddlerkelly's Avatar
fiddlerkelly
I find at times and just started recently when I go out and attempt to start the truck it will crank a few times before starting and then other times it starts fine.
Would this be the same problem as loosing pressure in fuel line as you guys have found or could it be something else. I have a 2006 dodge Mega cab by the way.
