transmission to radiator issue
Old May 3, 2010 | 07:46 AM
rwillie7926's Avatar
rwillie7926
Default transmission to radiator issue
Ok, so I leaked 4 qts when the hose blew off the rad. Fixed the hose , changed the filter, topped it off while cycling thru the gears. Ran great for 3 days. Now starts slipping after 1/10th mile. When shut off and restarted will engage again for 1/10th mile only. Check valve was removed by prev owner. Air flows thru radiator. With hose off, flow from hose while running in Drive is minimal. Bad filter? Miss a filter? Other thoughts?
Old May 3, 2010 | 11:12 AM
Possibly the filter came loose? Poor seal from filter to valve body?
Old May 3, 2010 | 06:18 PM
rwillie7926
Nope, filter was fine, good seal
Old May 3, 2010 | 06:29 PM
Can you check pressures?
Old May 3, 2010 | 07:34 PM
MonteC's Avatar
MonteC
Bad pump.
Old May 3, 2010 | 10:33 PM
rwillie7926
Is it replacable by a very capable DIY guy? Ease of replacement? Cost? THANKS
Old May 3, 2010 | 10:42 PM
MonteC's Avatar
MonteC
Im sorry to say but the pump going bad is only the start of the problems. Now your clutches are going to be glazed or burnt. I woulnt pull that unit out and just stick a pump in it. Waste of time, needs a rebuild.
Old May 4, 2010 | 08:22 AM
rwillie7926
I see rebuild kits online, are they all inclusive of parts or will I need other things like flexplate? Torque converter? Electronics? etc? I've done major engine work, never trannys but think it's well within my capavbility, thanks
Old May 4, 2010 | 01:04 PM
Flexplate: Only needed if yours is broke.
Torque Converter: Not a bad idea to replace with a rebuild. Good place for stuff to accumulate, and then come out into your fresh trans. Not a good scene.
Replacing sensors/solenoids/etc while you are in there wouldn't be a bad idea.
Don't know if any special tools are required for this evolution......
