superchip spark-knock
Old May 14, 2010 | 11:02 PM
ramsport-99's Avatar
ramsport-99
Default superchip spark-knock
This is a question for all those running the superchips 3815. I have been doing alot of research on this and im torn between dynotunning or buying the 3815, I like that i can update the superchips but i have heard that it will make ur engine spark-knock like crazy, so thats my question. Are ur trucks spark-knocking with the superchips, and how bad if so. Thanks
Old May 14, 2010 | 11:05 PM
Have you check your plenum gasket?
Old May 14, 2010 | 11:29 PM
dhvaughan's Avatar
dhvaughan
superchips only pings if the plenum is leaking. as will any timing advance.
Old May 15, 2010 | 12:35 AM
jasonw's Avatar
jasonw
Site Moderator
+2. After I fixed my plenum gasket, my 3815 no longer caused spark knock.
Old May 15, 2010 | 02:14 AM
TheBigRedOne's Avatar
TheBigRedOne
It will also knock if there is residual 87 octane left in the tank. When I did the Perf. 91 tune on my truck, it snap crackle popped under load. I put in some 91, w/ some octane booster to hep out what was left in the hoses, and drove it for about 20 miles.
It popped less and less until it went completely away. No problems since!
Old May 15, 2010 | 12:52 PM
ramsport-99
thanks guys, that was what i was hoping to hear
Old May 15, 2010 | 01:08 PM
lastrights's Avatar
lastrights
if you put in a 180 t-stat and colder plugs that will help also
Old May 15, 2010 | 01:42 PM
dhvaughan's Avatar
dhvaughan
that didn't help my leaking plenum, although high octane gas did.
Old May 15, 2010 | 01:52 PM
jasonw's Avatar
jasonw
Site Moderator
Colder plugs helped a little with mine, but it didn't go away completely.
If your gasket isn't fixed yet (if you haven't fixed it yet, or if a previous owner didn't fix it, it is blown BTW), thats step number 1 to solving spark knock.
