pilot bearing
Old May 22, 2010 | 09:33 PM
robsupra1's Avatar
robsupra1
Default pilot bearing
I am changing the clutch in my 1999 dodge ram 1500 v6 5 speed, trans is off along with pressure plate clutch and flywheel. I cant get the pilot bearing out of my crank, antone know any tricks??
Old May 22, 2010 | 09:38 PM
Pack it with wheel bearing grease, get a bolt/rod/whathaveyou that is VERY close to the same diameter as the shaft that fits in there, stick it in the hole, and whack it with a hammer. Pops it right out.
Old May 22, 2010 | 09:40 PM
GeorgiaDodge's Avatar
GeorgiaDodge
on a ford 390 i would fill it up with grease and hammer a rod that would fit tight in the bearing, pull it out and then add more grease and hammer away. the grease will eventually push the bearing out. messy i know but it was how i learned from an ole timer that had been working on cars his whole life.
Old May 22, 2010 | 09:46 PM
GeorgiaDodge
beat me to it. damn im a slow typer
Old May 22, 2010 | 09:47 PM
I'm an old timer too.
Old May 23, 2010 | 12:42 AM
95RAM360's Avatar
95RAM360
i just did a clutch in my buddies 94 Nissan 4x4 (i know its not a Dodge, but same basic thing)...i loaded it with grease, and stuck two small screwdrivers in, each facing a different way so it could grip, then i slowly worked it out...manuevered the screwdrivers to act as a type of "prybar", and i just pushed the ends, rotate a little and repeat.
Old May 23, 2010 | 03:43 PM
robsupra1's Avatar
robsupra1
ok thanks everyone. ill give it a try
Old May 23, 2010 | 04:17 PM
UnregisteredUser's Avatar
UnregisteredUser
You may be able to rent a pilot bearing puller at an auto parts store. If you've got one on hand when you need it, it's quicker, easier, and a lot cleaner. But the grease trick works well, too.
