Plenum Repair Materials
Old 06-01-2010, 04:13 PM
J McWillis's Avatar
J McWillis
J McWillis is offline
V10 is an 8.0L IIRC. I don't know the setup in the thermostat housing on those but on ours it's just a tiny thing. Alot of it could have to do with supply/demand. Not nearly as many 10's running around compared to our 8's.
Old 06-01-2010, 04:30 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,268 Likes on 3,015 Posts
Originally Posted by truegent81
so i was about to purchase a new water pump from moparonlineparts.com but ive noticed on some parts it states "w 8.0L" or "w/o 8.0L". what is the 8.0L they are talking about? i think it is the v10 but on some parts the only option is 8.0L...just double checking before i order it.
for example: why would a termostat housing for a ram with a 8.0l be $100 but w/o a 8.0L it is $6? TIA
Originally Posted by Nando Vazquez
yeah i think that refers to the V-10 engine. Not completely sure.
8.0 liter is indeed the V-10.
Old 06-01-2010, 04:56 PM
Nando Vazquez's Avatar
Nando Vazquez
Nando Vazquez is offline
When I repair the plenum leak would it hurt to use some seafoam in the intake prior to the repair. Would this make the cleaning procedure easier or is this a bad idea.
Old 06-01-2010, 08:16 PM
HeyYou is offline
You can... but, the inside cleans up fairly easy anyway. (brake cleaner works ok, simple green works pretty good, and reportedly, so does oven cleaner....)
Old 06-01-2010, 09:44 PM
CPTAFW163's Avatar
CPTAFW163
CPTAFW163 is offline
you are spending too much.
Hee is your list with links:
1. Plenum kit: $86
http://www.hughesengines.com/Index/p...z&partid=22220
2. Intake bolts and gaskets: $44.90
http://www.hughesengines.com/Index/p...b&partid=23039
3. Full ignition tune up (Plugs, wires, cap rotor): $99
http://www.summitracing.com/parts/ACC-TST24/
4. Injector o-rings: $7.50 (YOU WILL NEED 2 of these!!! injectors need one on top and one on bottom)
http://www.summitracing.com/parts/SMP-SK1/
5. 180* stainless steel thermostat: 12.95
http://www.summitracing.com/parts/JET-10170/
6. Bypass hose: 2.95
http://www.summitracing.com/parts/GTR-63064/
7. Upper rad hose: 13.39
http://www.summitracing.com/parts/GTR-62069/
8. Lower rad hose: 11.95
http://www.summitracing.com/parts/GTR-62070/
9. Get the coolant at wallmart, it is about 6 dollars cheaper than autozone (autozone wants 15 bucks for extended life antifreeze). You will need at least 1 jug for this.
10. Oil change: wherever you buy oil. You will need to because you will get coolant in the oil doing the plenum.
11. Large tube of Permatex ultra black (you should use a lot of this for the frong and rear of the intake): about $10
12. Small tube of Blue Loc-Tite: about $5
13. Coolant temperature sensor: 35.95 (Autozone sells a duralast for 12.95)
http://www.summitracing.com/parts/SMP-TX71/
I hope you have a full set of tools, Primarily 9/16, 1/2 ratchet and crescent wrenches as well as a set of alan key wrenches.
** when you take the intake bolts out, take 4 of them and cut the beads off them. then put them in the intake holes when you are putting the intake back on. it will ensure that your intake is perfectly lined up and you do not shift any of the gaskets**
Don't worry about the Throttle body gasket
Old 06-01-2010, 10:31 PM
PurplDodge's Avatar
PurplDodge
PurplDodge is offline
I just recently replaced the water pump, but I dont think I can replace the timing chain, i dont know how to align it properly.
Open up the service manual, you are gonna need it. Just line up the two dots on the timing chain.
In your list, I didnt know Duralast made spark plugs. Probably worth as much as the other Dura-not-last crap. Get Champions or NGKs.
Old 06-01-2010, 10:35 PM
PurplDodge's Avatar
PurplDodge
1. Plenum kit: $86
You are spending too much.
Get everything from here:
http://www.rockauto.com/
The best damn place to get auto parts, I dont care who you are.
Old 06-01-2010, 10:43 PM
CPTAFW163's Avatar
CPTAFW163
Yeah i go to rockauto for sensors and oem parts. But they are a bit lacking on the stock parts. I got everything from summit (except the coolant temp sensor, MSD coil, and plenum kit) because the shipping from going to rockauto AND summit would have pretty much balanced out.
I got all my sensors from rockauto when i had the fire in my 1996.
Old 06-01-2010, 10:47 PM
PurplDodge's Avatar
PurplDodge
Rock Auto kicks ***, I dont know how many times I'm gonna emphasize that! If you pay attention on the site, get all of your parts so they ship from one warehouse, it saves you on shipping and everything arrives in one box.
Also make sure you get a new Goodyear belt and Dayco tensioner and idler pulley. I didnt and wish I did, only to replace them both a month later.
Old 06-01-2010, 10:50 PM
CPTAFW163's Avatar
CPTAFW163
I heard the goodyear gator belt was not very good?
Funny thing, I was thinking of getting a new belt and idler pulley yesterday!!! I had an idler pulley go out on me when i was moving from NY to Oklahoma. Somewhere in Virginia. Now, when i move, i keep a spare belt AND idler pulley around.
--Dan
Quick Reply: Plenum Repair Materials
