Eaton seems to be a well known, and accepted brand. Not sure where you are at right at the moment, so, check out THIS page, give it your info, and you should be able to come up with something.
It would the dreaded 4-wheel parts out in So Cal. I've got a mechanic friend of mine who, already stated that he can get Eaton and Aubrey diffs. I'm going to hit him up in the am and get the ball rolling on these. They work on electromagnetic principal which, is very reliable. I can see this working out for me over a high maintenance unit or something is going to fail over time.
