Dissolving Locktite
Old Jun 6, 2010 | 07:25 PM
aim4squirrels's Avatar
aim4squirrels
Default Dissolving Locktite
Well crap,
Snapped a header bolt off in the cylinder head. I think I have enough left sticking out to dremel the end and back it out with a long screwdriver, but that won't get me much torque and I used blue locktite on the threads.
What dissolves locktite? I'll probably have to use a ton of that and then some knocker loose.
Old Jun 6, 2010 | 07:31 PM
dodgeram07's Avatar
dodgeram07
Acetone
Old Jun 6, 2010 | 07:37 PM
aim4squirrels
I will add that specifically it is permatex blue threadlocker.
I will give the old acetone a try. I've also heard MEK works, but I like my liver, and I'll avoid that if I can.
Old Jun 6, 2010 | 07:39 PM
UnregisteredUser's Avatar
UnregisteredUser
Heat the area and extract the broken piece while it's hot. Sometimes it helps if you rap the fastener with a hammer.
The official remover is methylene chloride.
Old Jun 6, 2010 | 07:50 PM
ghost4321's Avatar
ghost4321
Heat will break down the thread locker. The permatex website says the high temp stuff is good to 400*F so it probably break down around 500*F.
Old Jun 6, 2010 | 07:57 PM
dodgeram07's Avatar
dodgeram07
ya you got to save it for drinkin
Old Jun 6, 2010 | 08:03 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Man, can MEK even be acquired without a permit? In the Navy, the guy who ran the paint locker on board ship smoked with an open 55-gallon drum of MEK right there.
Anyway, heat always works. You know the old saying, "Kill it with fire!"
Follow this man's wisdom.
Old Jun 6, 2010 | 08:46 PM
Laramie1997's Avatar
Laramie1997
Here I was all gung ho to tell you what the solution is, and then I walk away from the comp for a few minutes.
Anyways, I've always had good luck with getting the piece out by itself, soaking in wd-40 and then applying propane heat. Makes the surrounding area look not so pretty, but it usually works....
Man, blue locktite??? Bet you wont be using that one again.
Old Jun 6, 2010 | 09:52 PM
jpbalt's Avatar
jpbalt
I was on a racing team for years and we always used a propane or Mapp gas torch on blue or red loctite. Heat even works on green (sometimes).
Old Jun 6, 2010 | 10:41 PM
beamwalker's Avatar
beamwalker
+1 on the heat wrench
