Hemi Swap into a 2nd Generation Ram
Old 08-30-2010, 08:59 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
damn sam that's a lot of work. you must really, really want a hemi.
good luck with it.
Old 08-30-2010, 09:49 PM
mrfarrell's Avatar
mrfarrell
mrfarrell is offline
some guy over on another forum put a hemi into a dakota..should be very similar..don't have a link handy thou..
Old 08-31-2010, 11:15 AM
DDIRI's Avatar
DDIRI
DDIRI is offline
I've seen several of the Dakota hemi swaps online and one into a Dakota with a blower on it. There is one hit over at pirate 4x4 that put one in a 94 ram but the thread died before he finished. He was doing a lot of time consuming suspension stuff on top of the hemi swap. Google" hemi swap and more" to see his write up.
Old 08-31-2010, 01:34 PM
Annihilator_X9's Avatar
Annihilator_X9
Annihilator_X9 is offline
Wow, this is awesome! I'd also love to see the end result!
Old 08-31-2010, 01:36 PM
Harufox's Avatar
Harufox
Harufox is offline
lookin forward to more progress .. i always wanted to put a hemi into my 2nd gen
Old 09-04-2010, 08:17 PM
DDIRI's Avatar
DDIRI
DDIRI is offline
After a week of working I got the Gen3 dash into my 97. Hemi is in the truck. I'm waiting for it to cool down outside. Motor mounts are getting measured and fabricated as soon as it drops below 105. Going to throw up some pictures tomorrow.
Pre Yank 5.9 Engine Bay
Post yank Engine Bay
5.9 For sale if any one is interested comes with a leaky 46re ha ha
Hemi going in
Hemi sitting where it will be till I get my Frame mounts fabbed
So Far here is my list to completion
TO DO
1 Fabricate Frame Mounts
2 Fabricate Dash mounts
3 Install Hemi Fuel Pump
4 Wire up Dash
5 Install Radiator AC Cooler and fabricate Mounts
6 Install all components
7 Convert Vacuum CAD to Manual cable CAD
8 Hook up Heater Core
Things I still need to buy
1 TCM
2 ECM Pin Connectors for the two that got broken
3 Stock Hemi intake
4 APPS Setup
5 Remote Oil Filter
6 PWS
If anyone knows of a good place to Get any of these parts I would very much appreciate it.
Things Left to figure out
1 Brake lines (the new vacuum assist doesn't line up with my old lines need to find a place to get flexible lines)
2 Rear drive shaft needs lengthened
3 Front drive shaft need u joint pressed out
4 Wiring on Headlights ,tail lights, Brake lights, turn signals etc
5 Steering shaft extension where to buy
If any one has a fix or any kind of insight for anything please chime in I'm always looking for a better fix.thanks.
Old 09-09-2010, 02:30 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,206 Likes on 2,958 Posts
Can't you just bend the brake lines to where you need them to be?
For the U-joint, I just support the joint on two blocks of wood, and whack the shaft with a dead blow hammer. Knocks the joints right out. Very easy.
Old 09-09-2010, 02:46 PM
DDIRI's Avatar
DDIRI
DDIRI is offline
The Fittings are different sizes. I'm kinda worried about kinking a line too.
Old 09-09-2010, 02:48 PM
HeyYou is offline
I hand bend lines on a fairly regular basis. The tool is also rather cheap.
You can get the correct size fittings at any parts store, and just re-flare the end of the line. Probably going to have to do something custom anyway......
Old 09-09-2010, 03:33 PM
DDIRI's Avatar
DDIRI
DDIRI is offline
Never bent lines before. Let me know how to do it what tool I need and I'm all over it like water on an oil slick
Quick Reply: Hemi Swap into a 2nd Generation Ram
