Hemi Swap into a 2nd Generation Ram
Old Jan 14, 2012 | 11:27 AM
  #261
I think that just disables the doors from locking when the truck starts rolling, or, when you close the doors, and walk away.
Old Jan 14, 2012 | 11:29 AM
  #262
HemiDak-Quad's Avatar
HemiDak-Quad
Originally Posted by DDIRI
The problem with the Chrysler Sentry Key system is that after three attempts the computer locks you out and you have to go to the dealer to get it unlocked.
Even if you do get it to run without the right key , It will only run for two seconds..
Old Jan 14, 2012 | 11:59 AM
  #263
HemiDak-Quad
Yes , But it might reset the security system.."Maybe"....
.. "THE SOLUTION"..
I would take the dash back out and put the old dash wiring and everything else you took out of that cab back in , including key switch steering column and everything..Start all over..
OR get Dodge to help you....you'd get more out of trying milk a Bull..
Old Jan 14, 2012 | 12:41 PM
  #264
DDIRI's Avatar
DDIRI
I don't have the original dash. I wired everything up but the door locks don't work still. I was going to wire my doors up using my old pdc but the panel for my truck was inside the truck under the dash. I may have to buy another cause it looks like the old truck locks were reverse polarity where as the new one I'm not sure.
Old Jan 14, 2012 | 02:24 PM
  #265
HemiDak-Quad
You don't have the original wires for the truck ? I'll send you a 2003 dash wiring harness if you think it will salve the problem..
Old Jan 14, 2012 | 02:27 PM
  #266
HemiDak-Quad
I don't have a kick panel harness..
Old Jan 14, 2012 | 02:28 PM
  #267
Would still need to get rid of the alarm from the PCM, if it's factory.....
Old Jan 14, 2012 | 03:03 PM
  #268
DDIRI's Avatar
DDIRI
i figured it ou you have to touch the disarm wire to the arm wire and that seems to have stopped the alarm as well as the red light blinking on my dash. My ruck will still not crank however. I have checked the grounds and they are all fine. My multimeter read the battery at 14 which I think is normal. I'm going to check my fuses and relays to see if they are all in working order, but aside from that I am lost.
Old Jan 14, 2012 | 03:13 PM
  #269
Are there wiring diagrams available somewhere? (free.....)
Old Jan 14, 2012 | 03:20 PM
  #270
merc225hp's Avatar
merc225hp
Just an idea, Why not use a remote starter button to see if you can get it to turn over that way. If it does not turn over using the starter button it would narrow down your hunt somewhat. Could be a bad starter.
