Hemi Swap into a 2nd Generation Ram
Old Jan 14, 2012 | 03:27 PM
  #271
DDIRI's Avatar
DDIRI
It cranked last saturday that's what is so baffling about this. Hemi dak the Gen 3 rams don't have an interior fuse panel. The Gen 2 rams do. My number 21 22 and 23 fixes were blown. Not sure what they run but I replaced them and still no cranking. I wish I could hit a reboot switch and set everything back to factory. I miss the days of being able to dump fuel in the carb and cranking to see if a motor is good or not.
Old Jan 14, 2012 | 03:59 PM
  #272
HemiDak-Quad's Avatar
HemiDak-Quad
You got the flashers to quit flashing and everythings back to normal on you're dash ???
Congrats on that......Now , it still won't spin over ? Which computer do you have in it ?
Sounds to me like you have an issue someone would have to be looking at to figure out..Keep us posted , I'm confident that you'll figure it out .. If you have to ~, look back on some of the Ideas we talked about before..If you have any questions about anything , wiring etc...I'll be here...
I have learned about as much from trying to help you as I did with my own truck..
I don't know everything by no means , and I'm still learning .. we'll figure it out , just pay close attention to certain wires , like red , yellow , brown and GR/OR.. ALL POWER WIRES...
Old Jan 14, 2012 | 04:03 PM
  #273
DDIRI's Avatar
DDIRI
Yeah the flashers quit. I have tried both ECMs to no avail. not sure if I am getting a good connection from my ECM plugs two of them were slightly damaged in the rollover. I'm going to pull them and see if any pins are pushed out of place on the plugs. all my wires seem to be going where they are supposed to. I'm debating a cab off rebuild of this thing. If I cant figure something out I am going to have to start over.
  #274
HemiDak-Quad
Dito brother u and I Both....The Dakota has the inside fuse panel also..I checked on carberating my RAM "You don't want to know what that would cost..I would have to sell one of my Harleys to do it..
Old Jan 14, 2012 | 04:08 PM
  #275
HemiDak-Quad
Unfortunately , Sometimes square one is the only place to start.................. ......................... It sux when you can see the finish line but it ends up being the starting line instead..
Old Jan 14, 2012 | 04:10 PM
  #276
DDIRI's Avatar
DDIRI
Yeah I am sure you felt that way when you got hit in your dakota. I looked into carbs and for 6k I could take it to a shop say "get the motor going throw a turbo on it and drop it off later this week." The price isn't worth it. plus you lose power and fuel economy.
I just was out going through everything again I notice I am not hearing my fuel pump cycle when I turn the key. The scan tool is saying that it cant communicate with the PCM . This is really strange I haven't done anything since last saturday other than try to readjust the PCM and swapping in and out the two I have. I have been reading and it seems other people are having the same issue I am.
Old Jan 14, 2012 | 06:03 PM
  #277
rapidtransitric's Avatar
rapidtransitric
try this
http://www.4shared.com/document/uUNW...ce_Manual.html
Old Jan 14, 2012 | 06:07 PM
  #278
DDIRI's Avatar
DDIRI
Rapid What is that??? I can't see anything other than a bunch of black boxes......
Old Jan 14, 2012 | 06:19 PM
  #279
stewie01's Avatar
stewie01
It's a download page for the 2003 Service Manual.
Old Jan 14, 2012 | 06:26 PM
  #280
mrfarrell's Avatar
mrfarrell
i just read the last few pages...seems your having alarm issues...at my old job we use to get vehicles in with no keys all the time and had similar issues...the trick was to match the steering column with the ecm then it would run...you could run an automatic truck with a manual steering column and manual computer and a manual truck with a auto set up also, as long as the steering column matched the computer..normally if it was a skim truck we would use a skim column thou..so this may attribute to your issue..also the ignition switch on the 02-05 rams with tilt columns had issues with the ignition switch and wiring harness going to it melting, id inspect that also..and the factory alarm get disarmed and reset when you disconnect the battery...
