Hemi Swap into a 2nd Generation Ram
Old 05-29-2012, 07:22 AM
rapidtransitric's Avatar
rapidtransitric
rapidtransitric is offline
if i remember correctly you would need a spacer plate to match the ports when putting a 6.1 intake on a 5.7. and putting a 6.1 cam in the 5.7 at this stage in the game would just ad to the fire you already have going. replace the 5.7 cam with a 5.7 cam. get it running and tuned properly first. get the bugs out!!!!!!
  #452
Old 05-29-2012, 01:03 PM
DDIRI's Avatar
DDIRI
DDIRI is offline
I agree rapid that was kind if my thought process.I can always upgrade later. I talked with my wife and she doesn't think I need more power she thinks I need a trick that runs can't really argue with that logic. I am on the look our for a new or gently used cam. I'm going to try patching the manifold the hole isn't that big. So I may post a thread in the G3 section. I will keep you guys posted. As much as it stinks at least I I know what it is I need to fix.
  #453
Old 05-29-2012, 01:54 PM
HemiDak-Quad's Avatar
HemiDak-Quad
HemiDak-Quad is offline
A stock intake manifold won't be hard to find or expensive. Going with a comp performance cam will require a tuner . As you know Super~Tuner options for the 03' ~ 04' Hemi's are very limited. If the finances are there to upgrade to a 05' pcm and wiring harness now would be a great time .
On the other hand I'm pretty sure Comp. sells cams close enough to stock they don't need a tuner..
I'm glad to see you found the problem . I don't know if it's possible to warp a valve if they open on TDC.. I'll be the first to admit I don't know everything about the Hemi's Like you I'm learning .. Post some pics if you can..
  #454
Old 05-29-2012, 04:35 PM
98hemi-ram's Avatar
98hemi-ram
98hemi-ram is offline
Yea im sure a stock 5.7 hemi cam shouldnt be to hard to find since there are so many hemi guys swapping them out. Id say i could send you one as i now have 2 hemi's sitting at home but i dont know when id have time to get it pulled out and i would imagine shipping would be out of this world coming from canada. But if you cant find one let me know and ill help yea out if i can.
  #455
Old 05-29-2012, 05:24 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
I wish i woulda held onto my dads 04 motor when it came out. I would have been able to pull the cam for you.. I might be able to see if the shop still has it if you would like.
  #456
Old 05-30-2012, 04:11 PM
DDIRI's Avatar
DDIRI
DDIRI is offline
Sure dlyter if you could that would be hear how much would you want for it? I'm thinking now I need to do every thing as cheaply as possible as well as keep it as close to stock as possible. Then once its running look into upgrades s far as a cam and harness go.that way trouble shooting will be easier.
  #457
Old 05-31-2012, 06:51 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
Well I went and talked to him and he had just sent the motor out on monday... I will keep lookin around here in the junkyards and whatnot to see if I could find one for ya.
  #458
Old 06-01-2012, 09:33 PM
1989double,d's Avatar
1989double,d
1989double,d is offline
nice project
  #459
Old 06-04-2012, 04:17 AM
DDIRI's Avatar
DDIRI
DDIRI is offline
Thanks for your help and support guys. I will be pulling the cam out tomorrow and the intake as well. Wish me luck that I don't find any more land mines on this project. The end is on sight.
  #460
Old 06-04-2012, 02:15 PM
HemiDak-Quad
" YEP ",The end is in sight . You've learned a lot with this truck , but schools about to be out . It's time to enjoy the fruits of you're labor..
Quick Reply: Hemi Swap into a 2nd Generation Ram
