Old Aug 13, 2015, 05:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Blend door fix
Old Feb 4, 2011 | 03:39 PM
  #31
sungod's Avatar
sungod
Originally Posted by zman17
The cable adjustment referred to is out of the 98 FSM. It's entirely possible that Dodge changed things through the years and is not an available option as a fix/adjustment on a 95.
Hey Z, any chance you can post the section that shows how to adjust the cable? I know you posted how to check it.
Old Feb 4, 2011 | 03:48 PM
  #32
zman17's Avatar
zman17
Retired Moderator - RIP
No prob.
Old Feb 5, 2011 | 03:38 AM
  #33
JWACGB's Avatar
JWACGB
Question
I am hearing the blend door opening and closing while im switching between the main dash vents and the defrost selections. I just don't know what elae to try. Other than snatching the entire dash out and replacing the heater core and radiator. Thank you all for your help. I really appreciate it.
Old Feb 5, 2011 | 11:33 AM
  #34
No you aren't. Blend door is actuated by the temp ****, and that's it. What you are hearing is the doors that direct air to the correct vents opening and closing.
Old Feb 5, 2011 | 11:59 AM
  #35
champion88's Avatar
champion88
Originally Posted by 73Red
I have a problem where my heat is just luke warm. Does not get any hotter when I accelerate. Could this also be my problem?
Pull you temp **** off, mine was doing the same thing and the **** was cracked where it fits on the shaft and not letting it turn all the way over to hot. Actually it flexes and you lose some of the travel.
Old Feb 6, 2011 | 03:16 AM
  #36
JWACGB's Avatar
JWACGB
I was reading through the repair manual that I bought when I bought the truck and it says there is a vaccum line connected to the back of the climate control **** assembly. Gonna remove that today and see if there is a problem there before I ****** the dash out. Once again thanks for all your help.
Old Feb 6, 2011 | 07:12 AM
  #37
JWACGB's Avatar
JWACGB
Well I took the Climate Control Assembly off and there are 5 vacuum lines on the back, 1 cable and an electrical connector. The vacuum lines were connected to the vent selection ****, the cable was connected to the temperature control ****.
Old Feb 9, 2011 | 02:10 PM
  #38
mygirlfrienddrivesaram's Avatar
Thank you. This information is going to help me a lot.
Old Jun 24, 2011 | 10:03 AM
  #39
bg56's Avatar
bg56
Default Any 99 dodge rams out there using blend door repair kit?
Just wondering how many folks out there have done the HeaterTreater blend door repair on a 1999 Dodge Ram. Seems like mine is broken based on symptoms (A/C runs for a few minutes, reverts to air and stays until I turn off the system and let it rest a moment). $700+ to repair even at my reliable repair shop plus the chance for dash damage which would lead to a replacement dash for $400. I think not for 1999....
Hoping to compare notes - not a mechanic by trade but this repair looks very doable and would like to hear from folks that have done this repair.
Thanks
Old Jun 24, 2011 | 10:26 AM
  #40
I don't know what year Dodge went from the cable operated blend door, to the motorized one. If you do indeed have the little motor, the fix is easy, two screws, and an electrical connector. One of the screws is reportedly difficult to get to though. I think there was a How To, (video even) on their site..... Doesn't really look that bad.
