Which wheel cylinder?
Old Jul 8, 2010 | 06:08 PM
Originally Posted by Chadlow21
Ok, this may sound stupid. What size does it need to be? I see that stock is 15/16 diameter. All of the others are bigger, right? So how do they fit?
That's the bore diameter. (internal dimension) They are all pretty much the same length, and mounting style. there is plenty of room inside the drum for them, and the larger bore, means a larger piston, means more area for the fluid pressure to work against, means more effective back brakes.
That was a mouthful.
Old Jul 8, 2010 | 06:40 PM
EndIsNear's Avatar
EndIsNear
Originally Posted by dhvaughan
if you want to get more confused (or unconfused) look into the details of bore size on various years.
a dodge 2500 cyl is bigger than the 1500
and the mid-90's chev 3500 is the biggest of all.
i think rockauto has the size specs.
check your fits carefully. squirrels screwed up his brake drum doing that on an 01. he realized too late that it didn't fit right. i THINK 94-99 is ok, but 00-01 might not be.
Wait, so you can't increase the wheel cylinder size at all on an 01? I'm in need of redoing my brakes and want to do this also...
Old Jul 8, 2010 | 08:58 PM
dhvaughan's Avatar
dhvaughan
according to my 10 seconds of research, the 01 stock diameter is 1 inch on 1500/2500/3500. you can get a larger bore from the 3500 chevy single wheel, and even larger from the 3500 chevy dual wheel.
i didn't say it wouldn't work. i said to measure carefully, check your fits, and make sure it fits right. something bad happened to squirrels 01 when he tried this. i don't know what or why, but i'll ask him.
one little thing to know, is that on the 00 and 01, the angle of the brake line fitting changed from 90* straight in, to a 45* forward angle. that creates a separate left and right part number. so you might need to rebend your line a smidgen.
story of success.
https://dodgeforum.com/forum/2nd-gen...p-upgrade.html
story of fail
https://dodgeforum.com/forum/2nd-gen...ated-crap.html
Old Jul 8, 2010 | 09:52 PM
SplatSTi's Avatar
SplatSTi
tagging since I want to do this to my truck too.
