Old Aug 7, 2015, 01:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Diagnostics
Print Wikipost
Leaking oil
Old Jul 7, 2010 | 06:30 PM
barrypotts1b's Avatar
barrypotts1b
Question Leaking oil
So my trucks leaking oil. I know this is severely common especially in older trucks. It leaks every night and a decent amount. It seems like it is coming from the left side of the engine. By the tire. It might just be running down there and thats where it falls. What can be wrong? Or should i just deal with it.
Old Jul 7, 2010 | 06:40 PM
03neonSE's Avatar
03neonSE
Time to get dirty. Crawl on your back, take a flash light and trace it. Its all I can tell you.
Old Jul 7, 2010 | 08:27 PM
dhvaughan's Avatar
dhvaughan
it wouldn't be the axle seal would it ?
if engine, check valve cover gaskets. the bolts are probably loose and snugging them up tight might help.
Old Jul 9, 2010 | 04:32 PM
barrypotts1b
Crawled under there today and i was right. It is dripping down right by the tire. Off the axel i believe.
I cant get importing pictures to work because i took them from my phone. But heres a pic from google. Looks like maybe my axel seal is broken. But it feels like motor oil when it drips. Is gear oil and motor oil similar?
Its oily by that yellow arrow and under it. dripping down
Any ideas on how to fix?
Thanks i dont know anything about this crap
Old Jul 9, 2010 | 04:36 PM
Need to put the full path in the image tags.
Old Jul 9, 2010 | 11:00 PM
dhvaughan's Avatar
dhvaughan
axle seal.
http://www.pavementsucks.com/tech-article-3.html
http://www.pavementsucks.com/tech-article-5.html
warning - this is a fairly hard job. you have to disassemble the entire @#@-damn *&#$-ing front end, including pulling the axles and front differential. you risk destroying the two $180 bearings, and have to buy or make a seal puller to seat the new ones. you'll need impact wrench, jacks, jack stands, pull bars. while you're in there that deep, its a good time to replace brakes, bushings, u-joints, etc, which makes it take longer. i did all this recently and it took me a couple of days. that's why it costs so much to pay a shop to do it.
Old Jul 9, 2010 | 11:14 PM
aim4squirrels's Avatar
aim4squirrels
Gear/Diff oil is a little thicker than motor oil, but stinks something awful.
Old Jul 10, 2010 | 12:34 AM
edlucky1's Avatar
edlucky1
If you really want to trace ut use some UV dye. Yjay stuff is amazing at finding leaks.
Old Jul 10, 2010 | 09:14 AM
barrypotts1b
for a temperory fix, before i go to the shop, cant i just refill some of the gear oil. WHere can i fill it? Pics would be nice
Old Jul 10, 2010 | 09:19 AM
aim4squirrels
Rubber plug on the Diff cover. Pull it and fill with gear oil up to the plug hole. Fill it on a level surface.
