Drive shaft U joints
Old Jul 20, 2010 | 12:06 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Question Drive shaft U joints
How many diver shaft U joints are there on a 4wd the people at summit said 5 or 6 I forget. Is there really that many of them? I know there are 4 at least, I guess there is one hiding under that rubber pice on the front drive shaft?
Old Jul 20, 2010 | 12:54 PM
there are three on the front shaft. The 'joint at the t'case has two.
Old Jul 20, 2010 | 02:20 PM
dodge15004x45.9
Well I got 6 coming just incase I **** one of them up.
Old Jul 20, 2010 | 04:16 PM
lord0fsal3m's Avatar
lord0fsal3m
yea i think its 3 on the front shaft, 2 on the rear, and one on each front wheel
Old Jul 21, 2010 | 09:22 PM
DODGEIT105's Avatar
DODGEIT105
The front shaft where it connects to the transfer case is a CV(Constant Velocity) joint and will have two joints in them.
Old Jul 22, 2010 | 08:20 AM
olyelr's Avatar
olyelr
Max, there is also a ball and spring setup between the CV joint on the front shaft. Make sure you get those parts as well. They are probably shot too.
Old Jul 22, 2010 | 03:54 PM
dodge15004x45.9
**** a little late parts are here.
Old Jul 23, 2010 | 10:48 PM
olyelr's Avatar
olyelr
Sorry bout that, poon master.
Old Jul 30, 2010 | 08:16 PM
Grn Ram sport's Avatar
Grn Ram sport
Hey, how much did the u-joints run ya for the rear shaft? The dealership in town wants $115 to $125 depending on the drive shaft (1 piece, 2 piece.).
I found some online for $58.46, for both shafts. Mopar parts.
I can save $190 dollars in labor, and avoid being bent over.
Old Jul 30, 2010 | 08:44 PM
dodge15004x45.9
Like 20 bucks a pop. Call summit they will get you the right parts. I had mine in 3 days from ohio to pa.
